Another Oil thread!???!
Old May 28, 2010 | 07:56 AM
dadon's Avatar
tried searching to see if someone had same issue
So I'm driving to my home town today in my TL and decided to do an oil change last night, it didn't need it but something kept telling me to change so i did, i used mob 1 extend per. 5/30
with mob 1 filter. m1 110
it was easy buuuuut when I was done, I went straight to bed didn't even turn the car on.
this morning Engine light is on...
checked everything, no leaks, and car runs smooth
any idears??? before I go to advance auto at lunch.
Old May 28, 2010 | 09:14 AM
nfnsquared's Avatar
I would think you'd get the low oil pressure icon if it was due to lack of oil. Did you also just fill up with gas? Could be gas cap message (not sure if you get a separate message on the MID for the 06TL). Did you do anything else besides change the oil? Could just be coincidence and you have another issue cropping up that is totally unrelated to anything you've done. Best to just get the code read and work from there.
Old May 28, 2010 | 11:06 AM
01tl4tl's Avatar
did you put the right amount of oil in the engine?
and no puddle on the ground this morning?
Old May 28, 2010 | 12:50 PM
dadon's Avatar
oil level is good no puddle
went to advanced auto
P0108 map/baro circuit Hight input
might have been when I changed the intake filter
Old May 28, 2010 | 01:27 PM
nfnsquared's Avatar
Go back and recheck the hoses near the MAP sensor/accordion intake tube. People have inadvertently knocked a hose loose during air filter changes which causes that CEL. There is a post/s about this somewhere here in the 3G forum.
I seem to recall that it's also possible to damage the MAP sensor during the filter change. I guess it's sensitive to being banged around. You might need to replace the sensor.
Old May 28, 2010 | 02:41 PM
Majofo's Avatar
You probably disconnected / loosened the harness.
Old May 28, 2010 | 04:07 PM
wrxyboy's Avatar
1st TL-S on air in
hope you dont need to change the sensor but be sure to check all the connections. I did that stupid mistake once and it drove me crazy looking for other possible problems
Old May 28, 2010 | 04:13 PM
mcmanut's Avatar
You may want to double check to make sure the old oil filter gasket is still not on the mounting surface. A double gasket could cause this.
Old May 28, 2010 | 04:16 PM
nfnsquared's Avatar
Yeah, sorry, if it's the MAP sensor, it'd be the harness. Here's picture of the MAP sensor and harness:
https://acurazine.com/forums/showpos...88&postcount=6
Old Jun 1, 2010 | 11:45 PM
dbqkqh's Avatar
Hm, did you manually reset the warning after changing the oil?
:P
bungln
Feb 20, 2019 08:47 PM
thegipper
Oct 21, 2015 07:19 AM
robm
Sep 18, 2015 07:53 AM
datadr
Sep 12, 2015 09:12 PM
Aleax
Sep 11, 2015 11:31 AM
