Amsoil way full tranny oil change on TL?
There is a suggested way of changing tranny oil on Amsoil web site when you can change all the oil at once by disconnecting oil hose from tranny and it goes without full flash. Basically it is alternative to full flash and continious drains and refils. My question is:
Has somebody done this way full tranny oil change on TL?
Out of my element on a TL as it does not have an external oil cooler, but what they will do is disconnect the line to the oil cooler, start the engine and allow the fluid to be pumped into a container while rapidly trying to keep the trans from running out of fluid.
Do it the right way, normal drain and refill and you'll be good to go. If concerned do the 3 x 3 method.
Ryan's loving his ATLP TL
This the procedure you want to follow:
http://www.in.honda.com/Rjanisis/pubs/SN/B080100.PDF
mada51589
05-03-2022 08:54 PM
mugen_kid
11-13-2015 10:38 PM
HydrasunGQ
09-14-2015 10:14 PM
