Am fogs and headlight bulb replacement
Old Mar 9, 2013 | 05:19 PM
Kemstarr's Avatar
Hey AZ , i just recently put in some DDM lights in my fogs. They where working for a while and then out of no where the 10 amp fuse started blow. i would like to know if i have to install a relay for them or is something else the problem. Also i want to change the OEM 43K bulbs in the headlights to 8K but cant seem to find how to get to them. Will i have to take of the bumper? Thanks in advance!!! Kem
Old Mar 9, 2013 | 10:14 PM
MEKO's Avatar
Could reach from the inner fenders, no need to take out the bumper
If you search, you will find every detail
how to remove the bolt on the plastic cap
how to remove the plastic cap (by turning)
then you twist the power source and pull it back
then you push those 2 metal clips back and to the sides (clip falls down)
you take out the bulb, put the new one in
Removing the bolt on the plastic cover is kind of pain but flathead screwdriver will work
InFaMouSLink
Oct 27, 2015 06:51 PM
acuraST
Sep 17, 2015 02:31 AM
theinsvnity
Sep 10, 2015 10:22 PM
ellisd03tls
Sep 8, 2015 04:17 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
