alternator
alternator
hey everyone my Tl died on me about 2 days ago i am 100% sure it my battery and alternator hopefully ha but i just wanna make sure 04 Tl take the 130 amp instead of the 105amp. because i was told from auto zone it took 105amp but the guy was very unsure like he didn't know what he was doing but i think it takes 130amp can anyone clear this up for me?
thanks everyone
thanks everyone
Check the charging system first. I don't know how you're diagnosing the alternator without verifying in fact that it's not supplying sufficient amount of charge to the battery. In regards to the alternator, it supplies power as needed, going higher is not an issue although overkill unless you have aftermarket accessories that would call for a larger load.
You can hook up a charging meter to check the charge on your battery and the load from your alternator. Any national part store should be able to test it for free or you can buy one for $15-20 and test it yourself. Make sure you test the alternator at full load - radio, A/C, headlights, wipers, etc.. on.
The first and easiest test is to put a volt meter on it with the engine off. It should be just above 12 volts. Start the car and it should go to 14v. If fails this test, the alternator is bad. If it passes the test, it could still be bad.
As Majofo said, no issues with going with a higher amperage unit as long as the wiring can withstand the full output assuming you have something that will actually use the full output.
