Alarm Doesn't Activate + No Beep Confirmation when locking doors
my 07 tl + nav doesn't beep when i lock the doors and the LED alarm indicator on the door does not blink also. it doesn't matter how many times i press the lock button on the fob the factory alarm wont activate. all the doors are locked and i have physically tried to open each door to confirm.
i have made sure that the beep notification in the MID settings is on.
________________
when i lock the doors i do get some kind of weird harsh noise. maybe its a bad door actuator or something?
________________
also, i bought the car used and it has been in a head-on collision involving the hood and fender. i was wondering maybe because of the accident, something got messed up and the system thinks the hood is still unlocked.
in the very last post of this thread: https://acurazine.com/forums/showthr...ight=beep+lock
the op states that he/she "unplugged the hood switch". does anybody know how to unplug the hood switch?
_________________
if anybody has any insight, please help.
thanks.
________________
________________
_________________
thanks.
BANNED
sounds like a dead fuse. start under the hood and check each one, once you eliminate that, check under the steering column and make sure those fuses are good.
my car did this once, and i want to say i had a fried fuse under the hood...can't remember which one off the top of my head but i replaced it and good as new.
david_vang (12-26-2012)
i've checked all fuses and there doesnt seem to be any blown ones by doing a visual check.
there were however, two missing fuses under the steering wheel. the two missing were number 31 and 33 in the picture. for some reason they also have parentheses around the amperage rating so maybe they are optional?
i checked only strictly fuses, not sure what the little boxes in the fuse box under the hood were.
any ideas what else could be the issue.
if you are not getting the beep then that means something is still open. I'd be willing to be it's the hood latch sensor.
Undying Dreams (01-05-2013)
i dont mind buying a new latch as long as i know for sure that's the cause.
sucks because sometimes i would walk all the way back to my car just to make sure it's really locked.
BANNED
probably a dumb question, but is the battery in your keyfob operable?
on a realted note. the doors beep only with one set of key fob.
My wife's key fob works fine and car beeps. but with my keyfob the car never beeps. i didnt check if it alarm activates.
whats setting in MID are we talking of ?
in my mid it's set to beep.
doesn't make since if acura will only allow for one set of keys to activate the alarm though.
maybe with your keyfob you haven't set the beep in the mid?
if one remote allows it to beep, then the alarm is fine. It's your settings under customization on your set of keys.
i had a similar problem. turned out to be a $6 DIY fix. only took me a couple minutes to fix and im not that much of a mechanic .
https://acurazine.com/forums/3g-tl-problems-fixes-114/06-tl-door-sensor-how-do-i-replace-%2Apic%2A-876182/
Anthracite'04 (12-21-2014)
https://acurazine.com/forums/showthread.php?t=876182
thanks for the info.
rockyboy
08-04-2024 10:35 AM
tman570
06-11-2019 07:56 AM
peregrine22
ILX Audio, Bluetooth, Electronics & Navigation
01-12-2017 10:32 AM
ahsm
09-09-2015 08:35 AM
