Air Conditoner smoking?
Old Sep 6, 2014 | 12:10 PM
redsox68's Avatar
Ok, here is my latest 2005 acura tl problem. Yesterday when driving for about an hour on the highway I started to get smoke/steam through my center vent on the dash. I immediately turned the AC off and it stopped. It stopped so fast that it was hard to tell if it was smoke or steam. My temp gauge wasn't up or anything, I pulled over shortly after and popped the hood. The radiator looked fine and I didn't smell or see leaking coolant. My tl has 90000 miles on it. Any idea what the problem is? Thanks in advanced.
Old Sep 6, 2014 | 12:19 PM
Yikes's Avatar
My 2nd gen TL does this, as did my sister's 6th gen Accord, as did my father's Accords he had in the early 90s.
It is just harmless moisture. When it first happened to me I thought it was exhaust so I shut the A/C off.
Apparently it's quite common with Hondas.
Old Sep 6, 2014 | 01:00 PM
Jackass's Avatar
If you get steam/smoke when the AC is on, it can be a sign your heater core is leaking. I have seen it on two vehicles I have owned over the years. My wife's Equinox was doing this as well as frosting the center vents. However on the Equinox we could smell the coolant in the air. No "leaks" anywhere, just the sweet scent when the A/C was on along with the condensation on the center vents.
Old Sep 6, 2014 | 01:47 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
This happened to me recently. It may simply be low on R-134, causing the evaporater to ice up, then fan blows some water vapor out the vents. When was the last time you changed your cabin filter?
Old Sep 6, 2014 | 08:17 PM
redsox68's Avatar
I had a diagnostic test done on the ac in June and they didn't say it was low but I haven't changed the cabin filter in about 2 years/ 30000 miles.
Old Sep 7, 2014 | 11:29 AM
NBP04TL4ME's Avatar
What type of diagnostic test did they perform? Also if you have a leak (hoping I don't ), in the time that has passed since June, you may well be low now.
You should replace the cabin filter. It's simple to do and not expensive. It's not going to fix your issue but good general maintenance. I do all three of our cars once a year - cabin and engine filters.
Old Sep 9, 2014 | 04:15 PM
I hate cars's Avatar
It's normal when the atmospheric conditions are just right. Usually nothing to worry about. If you can't smell anything I wouldn't worry about it. Mine has done it a few times since the car was new and I've never had an issue with the system.
tsx_boy
Dec 13, 2019 08:33 PM
rcs86
Aug 2, 2016 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
jmaxima03
Sep 27, 2015 10:22 AM
prbori
Sep 27, 2015 01:37 AM
