Air Conditioning not blowing cold
Old Feb 21, 2026 | 07:22 PM
tyler_ua7_type_s's Avatar
My type s 07 is not blowing cold air at the moment, I checked pressure at low side, 45(full), ac fan turns on, and heat works just fine. No fault codes, no information from the ECU. The air is room temp at coldest, I dont know what could be causing it at this point, any ideas? Have any of you had this problem before???
Old Feb 21, 2026 | 10:00 PM
csmeance's Avatar
check a/c compressor clutch relay, you can swap it with the rear window defroster relay (they are the same) and see if that helps. If not, it could be a few other things!
Old Feb 26, 2026 | 12:58 PM
Checking pressure on just the low side is useless in diagnosing, go rent a manifold to check both sides simultaneously with the compressor on and off snd report back
Old Feb 26, 2026 | 06:15 PM
csmeance's Avatar
^ low side can help, if there is a big leak and the pressure is low it will not turn on the compressor! But if you add R134A and start hearing the compressor cycle on/off, then you know the issues is low R134A level. then a few days later it's not working, you have a leak!
Old Mar 23, 2026 | 09:52 AM
Chad05TL's Avatar
Since it was Feb 21 when you posted, what was the outside AIR Temp (ambient temp) when you measured the pressure?
If you have 45 psi and the temp was below 80, then you may have too much pressure
Old Mar 23, 2026 | 11:11 AM
marklittlefield4's Avatar
Sometimes a/c pressure switch gets stuck. Happened to me before.
Old Mar 23, 2026 | 01:29 PM
Novtec1's Avatar
Veteran: Army
^^^^^This right here... spent a whole week looking for leaks, fillinf and whatever else... just for it to be relay... did exaclty what was posted and the ac started working. Make sure to buy the right relay.
Amitabha
Jul 13, 2016 04:33 PM
DJRavi
Jun 27, 2012 08:02 PM
ChrisB88
Jan 23, 2007 05:31 PM
adonis_xu
May 6, 2006 10:17 AM
FRANKKIE
Dec 12, 2003 01:54 PM
