Air Conditioning Issue
Old Jul 19, 2012 | 04:10 PM
Platnm0705's Avatar
Unhappy Air Conditioning Issue
Ok, so my air conditioning isn't working right now, and I'm looking for some advice. I have searched on here and read everything I can find, but nothing seems to be the fix. Here's the rundown:
A/C worked when I bought the car a few months ago. Then, about a month ago when it was hot out, I turned it on and it worked fine. Drove to a store and when I got back in the car, it wasn't blowing cold. Stopped to get gas (during the same trip) and when I started the car again it worked fine. Then a few days later it wasn't blowing cold at all, and hasn't since. When I'm in the car and have the fan/vent on but the A/C off, and I turn the A/C on, I hear the compressor kick on and the idle change slightly, so I assume the compressor is working.
Took it to the dealership for the power steering recall and mentioned the A/C issue, they wanted $250 to do their test (full evac/re-charge, dye, etc). I told them not do the full test and just look it over. I don't know what they did but said they didn't find anything. The guy was really cool and recommended I take it somewhere cheaper just to get it diagnosed.
A few days later a took it to Firestone for an A/C check (they have a special on A/C service this month). They said it is slightly under filled and the A/C diode is possibly bad. I bought a new diode, and when I received it I tested them both on a multi-meter and the readings were the same, so it isn't the diode.
I have a hose/gauge from one of the self-refill cans of refrigerant and when I put it on (the low line of course) it reads way into the red. But like I said, Firestone said it was a tad low. Strange.
I checked the manual and ran the quick diagnosis (hold down Off, turn ignition to On, press re-circ 5 times) and it didn't throw any codes.
It is basically just like having the vents on. I don't ever have any smell coming from the vents or any other issues.
Anyone have any ideas? I'm a few days from biting the bullet and taking it to the dealership but would like to avoid that if I can. But with the heat wave here in NJ lately, driving to work and back every day is getting a little ridiculous.
Old Jul 19, 2012 | 05:04 PM
Turbonut's Avatar
Make certain the heater control valve is functioning properly and is in the closed position when the A/C is at max.
Old Aug 11, 2012 | 05:49 PM
tjmoneybags's Avatar
Ive been having this same problem as the original poster. I think the advice in the second is right....but how do I do that?
Old Aug 11, 2012 | 07:27 PM
Turbonut's Avatar
https://acurazine.com/forums/showthread.php?p=11381436
Old Aug 14, 2012 | 03:29 PM
that seems to be the opposite problem....no heat....I have no COLD. I don't think my compressor is clicking on.
Old Aug 23, 2012 | 01:07 PM
Platnm0705's Avatar
So I was about to bite the bullet and take it to my Acura Dealership to have it looked at (they charge $259). I just happened to look on the Hamilton Honda website and they are having a special on their AC service: regularly $149.99, on sale now for FREE. So I scheduled the service for Saturday and I'm picking it up on Sunday.
I'll post what they find when I get it back.
Old Aug 24, 2012 | 09:09 AM
Trunk Monkey's Avatar
Coolest A-zine Member
Good to hear. I've got an issue with the A/C also that I'm about to post up in a thread. Let us know what you find out
Old Aug 27, 2012 | 11:02 AM
Platnm0705's Avatar
Well it turns out to be a bad compressor and clutch. Dealer quoted $1150 to fix it, I declined. I'm going to shop around for the parts and for someone to install it, and will probably just get it done next year.
I'm disappointed that the car is only 4 years old and has 68,000 miles and this happened already.
Old Aug 29, 2012 | 01:20 AM
LADY-T's Avatar
Same problems
Took car for diagnostic at Pep Boys, ran complete diagnotic $50.00 says Evaporator Expansion Valve part would cost $41.99 with 12 mth limited warranty, they also have a limited extended labor warranty $47.85 total cost $658.96, must make decision within 90days.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
nanos
Nov 12, 2015 08:41 PM
PortlandRL
Sep 14, 2015 12:01 PM
