Air box noise when turning off the car?
When I turn off 08 acura tl type s, there is always the sound of a vacumn being released or something like this. It sounds like the air being quickly let out of a air box. I'm just wondering if this ir normal? after i took my car to acura for service, it started doin it.
They didn't seal the airbox properly after a filter install/check. Get it fixed quickly, you don't want dirty air going into the engine.
All TLs do this but the stock airbox muffles the noise.
[quote=RGarcia99;10169331]When I turn off 08 acura tl type s, there is always the sound of a vacuum being released or something like this. It sounds like the air being quickly let out of a air box. I'm just wondering if this ir normal? after i took my car to acura for service, it started doing it.[/quot
Any time you install an after market air cleaner special CAI your gonna get lots of noise coming from the intake. My other vehicle that's a Ford F150 was real noticeable at idle you could hear a lot of hissing coming from inside the air cleaner and when you shut it off you get like a whoosh sound, which is basically the vacuum (low pressure) in the intake equalizing with the high pressure out side the intake Throttle body.
only other thing could be a Vac. leak, TL have very little vac hoses compared to old Honda's looked like an bowl of spaghetti The TL has vacuum to the brake booster, evap canister, and i think for climate control actuators. and cruise control if it is not throttle by wire. hope this helps a bit.
tman570
Jun 11, 2019 07:56 AM
