again, o2 sensor, rear bank, primary
Old Mar 6, 2009 | 11:09 PM
lost's Avatar
9th Gear
Ive searched and read all o2 sensor threads I could find on the site and anywhere else I could.
I just wanted to run this by you guys, I have an 04 with 63k on it. o2 sensor is bad. My buddy at Honda had a tech test it, he didnt give me the code but he wrote down "rear bank. primary" They were doing it for free and I dont really know the tech so I didnt want to question it, I thought I could figure it out, but now Im looking at the link below and trying to figure out which out of numbers 9, 10, 11, and 13 I need to replace. I've googled all four part numbers and they all come up as oxygen sensors but I'm not seeing the same wording as what he gave me. Any thoughts? I'm thinking #13. Thanks.
http://www.acuraautomotiveparts.org/...s=&view=normal
Old Mar 7, 2009 | 09:18 AM
mn2trance's Avatar
All About Trance
I just had my O2 sensor replaced a couple of days ago on my '05 since my CEL came on a week ago. Have you gone to AutoZone to get a free reading, too? They'll print out the codes for you and see if it matches up to your read out at Honda.
Old Mar 7, 2009 | 04:43 PM
lost's Avatar
9th Gear
I went to two autozones and they said they stopped that service.
Old Mar 7, 2009 | 05:36 PM
Fulani has a TL's Avatar
Do you have an Advanced Auto Parts?
Old Mar 7, 2009 | 05:40 PM
I believe the rear bank is the rear converter, and the Primary is the first Sensor
Item Number 009 36531-RCA-A02 SENSOR, LAF
Old Mar 18, 2009 | 01:16 AM
lost's Avatar
9th Gear
Update.
Thanks for the help, I replaced #9 on Sunday and the check engine light has not come back on so I'm thinking that was the problem. It cost me $130 or so after shipping. It was a little hard to reach between the engine and the firewall but it worked out.
Old Mar 18, 2009 | 01:47 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
Good job assuming #9 was the O2 Sensor. Wished you did a DIY to help some people that are illiterate in cars like myself! (Maybe there is one on these forums, but too lazy)
Old Mar 18, 2009 | 01:54 AM
erick3's Avatar
on replacing the O2 sensor? the rear bank, primary O2 sensor really isn't hard to replace. all you need is an O2 socket wrench and you're good to go. all you need to do after loosing in the O2 sensor is unhook the harness that holds the clip (from the sensor). make sure that you DO NOT TOUCH THE NEW O2 sensor. Put it into a zip-lock bag in between transferring.
pm me if you have more questions
Old Mar 18, 2009 | 02:03 AM
Wait I was thinking about the Cat. Converter not the O2 sensor. Sensor is easy, Converter is kinda a pain in the ass.
Thanks though
Old Mar 18, 2009 | 03:07 AM
erick3's Avatar
Thanks though
what about the cat? if you're trying to do the pre-cat deletes from richie, you won't be able to pull it out up top...er least we couldn't. i took a long pole and hammer it out the other end that sob was a pain in my arse!
Old Mar 18, 2009 | 07:28 AM
mn2trance's Avatar
All About Trance
Originally Posted by lost
Update.
Awesome! That was half of my cost! LOL Then again, I did pay for the labor at the stealership.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
01CLOwner
Oct 9, 2015 01:07 PM
Sep 17, 2015 10:16 AM
EE4Life
Sep 11, 2015 10:13 PM
