Advice for timing belt
Ok im over 100,000 miles and well i need to change the timing belt according to the acura dealership. So im actually not going to go there bc they are charging an arm and a leg. So i have a friend that can do the job for me but id like to try to get the parts myself. What would be everything that I need and what brand or mark should i be looking for and what should i stay away from
here's the timing belt write-up with PICS
https://acurazine.com/forums/3g-tl-2004-2008-93/122-diy-105k-service-timing-belt-water-pump-spark-plugs-thermostat-%2Apics%2A-784622/
The gates timing belt kit has pretty much everything you need and contains all OEM parts minus the water pump. I installed the kit a few months ago and have not had a problem. It's way cheaper than buying the parts from the dealer.
the kit contains the following parts:
-Timing belt
-Water pump
-Idler
-Adjuster pulley
-Hydraulic tensioner
-Timing belt
-Water pump
-Idler
-Adjuster pulley
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
asahrts
Sep 4, 2015 05:55 PM
