Adhesive to fix aspec front lip gap?
I installed the front lip with extra 3M (extra strength) double sided tape but the gaps are still there. Has anyone tried another adhesive like epoxy? I was thinking about picking up some Loctite plastic epoxy. It has a 7 minute set up time but I'm not sure how I'm going to keep the pieces together other than just leaning against it. Any thoughts?
The gap is 2-3 mm. The double sided tape is still attached to both sides its just being pulled apart. Everything lined up perfectly just the sides are pulling apart. The back wasn't as easy but the tape has not separated.
I had a similar issue. Here was my solution. No matter how much time/patience, solvent and double sided tape in different configurations I could NOT get this thing to hold strong. Read this thread I had made.
https://acurazine.com/forums/3g-tl-2004-2008-93/anyone-aspec-annoyed-front-gap-my-solution-w-pic-767633/
justin7779
12-25-2015 10:33 PM
Pegon95
08-31-2015 02:18 PM
