i have a 2008 KBP Type S, I bought the car about two months ago. I am the 3rd owner. The car has complete service records done at acura dealerships. About a month after owning the car passanger side high beam and low beam stopped working. The parking light and DRL still work fine. It's not the D2S bulb because i replaced it and it still doesn't work. I'm assuming it's either the ignitor or the ballast. I just don't want to buy both and it only be one issue. Please help me, I'm tired of driving around at night with DRLs on
justnspace
close
- Join DateFeb 2010
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:16,291 Times in 11,991 Posts
swap passengers ballast over to drives side.
if problem follows ballast, bad ballast.
thoiboi
close
- Join DateApr 2010
- LocationSoCal, CA
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:9,177 Times in 7,050 Posts
Once you figure out which one it is, let me know, I have spare I can sell ya!
So you think it's the ballast and not the ignitor?Originally Posted by justnspace
swap passengers ballast over to drives side.if problem follows ballast, bad ballast.
justnspace
close
- Join DateFeb 2010
Quote:
the advice is the SAME.Originally Posted by AlGlizzy
Swap parts from RIGHT side to LEFT side to test/troubleshoot.
if problem follows parts, you know you have bad parts.
thoiboi
close
- Join DateApr 2010
- LocationSoCal, CA
You can either swap left to right or just buy additional of both and see which one is it and then sell off the second one
I have noticed that the 2008 Acura TL driver side DRL is in low beam position. Is there any way we can turn the bulb housing to make the bulb vertical?
thoiboi
close
- Join DateApr 2010
- LocationSoCal, CA
Quote:
I’m not sure what you are saying, can you elaborate and perhaps take a picture?
