acura tl cranks wont start
2004 tl cranks nwont start . been having this isssue ever since doing a heasd kaskets new every thing as in timing belt coils plugs battery . car will not start do not know where to start . has no codes getting fuel spark is ok compression ok
Latent car nut
Are you sure the timing is correct?
almostfinished (02-18-2020)
fixed
guys it was a ground from the battery even after checking it ws still bad . we took off the original cable and replaced it and all the other grounds with braided cable grounds and for the love of whoever you worship it fired up . ?/? sooo happy this nightmare of head gaskets is over . now just gotta wait till the tranny gives out for the next project . thanks in advance for everything i read on acurazine .
thanks but found it was a ground . after changing them to a braided cable it started up . but yes sir we checked that timing over and everything else even the grounds but third check revealed that bad ground . what a nightmare
Latent car nut
Thanks, glad you got it running. I'm also quite partial to the F4U. My profile picture is actually an FG1 I took a shot of over Camden harbor in Maine many years ago. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Teknikscian
07-12-2009 10:28 PM
