Acura TL 2005 positive cable battery replacement HELP!!!
Old 04-17-2018, 11:38 AM
5th Gear
Bigbandshawdy's Avatar
Old 04-17-2018, 11:39 AM
5th Gear
Acura TL 2005 positive battery replacement help
how do you get the green clip off . Every time I am pushing it out it doesn’t do nothing nor open if I mess with it also how do u unscrew a screw with that problem . It looks like something is stuck inside
Originally Posted by Bigbandshawdy
Old 04-17-2018, 12:39 PM
Received 8,709 Likes on 6,716 Posts
it's one of those push clips where you pry up on the clip. and pull away
and use a 10MM (i believe, maybe 12mm) socket instead of phillips head screwdriver to remove.
seanberry
02-02-2011 10:11 PM
reeves72000
1G TSX Problems & Fixes
11-30-2009 01:05 PM
richma7175
09-11-2009 06:11 AM
giggiTL
02-07-2009 11:51 AM
PSC
1G TL (1996-1998)
08-18-2008 08:06 AM
Quick Reply: Acura TL 2005 positive cable battery replacement HELP!!!
