Acura TL 2005 positive cable battery replacement HELP!!!
Acura TL 2005 positive battery replacement help
how do you get the green clip off . Every time I am pushing it out it doesn’t do nothing nor open if I mess with it also how do u unscrew a screw with that problem . It looks like something is stuck inside
Originally Posted by Bigbandshawdy
(Post 16220064)
it's one of those push clips where you pry up on the clip. and pull away
and use a 10MM (i believe, maybe 12mm) socket instead of phillips head screwdriver to remove. |
