Acura 2004 TL not starting
Old Mar 17, 2019 | 10:14 PM
Nickh36's Avatar
Hi ,
my Acura won’t start, driving one day and it just shut off. The lights all come on and the engine turns over but doesn’t start. I have spark, and fuel to the intake . I have plenty of fuel before it goes into the intake and goes to the fuel rail, injectors..I have eliminated spark, and I know I’m getting fuel so my question ... should I automatically assume that it’s the timing belt, as far as I can see the belt isn’t broken and it is still intact. Any info or troubleshooting I should do before assuming it’s the timing belt would be appreciated. Thank you
Old Mar 18, 2019 | 08:31 AM
Jackass's Avatar
You have spark, fuel, and air....that mostly leaves compression as the next culprit to investigate. Compression check possibly next? Otherwise I guess it is removing the covers and doing a closer look at the timing belt, tensioner, and cams.
Old Mar 18, 2019 | 12:50 PM
Nickh36's Avatar
Yes, compression is next , i was just going to check the fuel pressure regulator, before I moved to compression , but I couldn’t find it , unless it’s in the fuel pump? Do you know where is located ?
Old Mar 18, 2019 | 02:55 PM
Jackass's Avatar
No clue...I have been lucky and haven't had to do any digging around on the TL outside of basic maintenance.
Old Mar 26, 2019 | 07:39 AM
DMZ's Avatar
DMZ
Head a da Family
I had the exact same problem a couple of years ago. Turned out to be the + battery cable. At this age, it could easily be corroded internally where you can't see. That would be the next thing I'd try and replace. A relatively inexpensive fix!
Old Mar 26, 2019 | 11:26 AM
Nickh36's Avatar
Thank you , I’ll give it a try. Hopefully that’s it
Old Mar 27, 2019 | 07:35 PM
tds166's Avatar
Battery may also be low and not holding enough charge so car can't fully turn over. Happened to me a couple months ago. But after a period of time trying to turn it over I drained battery and got clicking. However, don't thunk you have that issue or not sure how many times you relatedly tried turning it over.
Graycie_TL
Jul 8, 2015 01:54 PM
007Cats
1G TSX Problems & Fixes
May 6, 2014 09:34 AM
Chopsie
May 22, 2006 03:23 PM
bimmer88
Technology
48
Apr 21, 2006 10:41 PM
RaptorCLS
May 15, 2003 07:51 PM
