2004 TSX Not starting.
Old May 5, 2014 | 09:19 PM
007Cats's Avatar
I have a 2004 Acura TSX Auto. 2 Days ago I turned on my car and I forgot something inside so I turned off the car. A minute or two later I came out, and the car wan't turning on or cranking. I tried jumping it, but that didn't work either. I took my battery to autozone and they said it had a full charge. When I put the key on, the lights on the cluster flash off and on. The only lights that come on when I turn the key to #2 position are the VSA/Ebrake/ABS. And they are very dim. And when I press the brake, all of them go off. Headlights and radio don't work either. Earlier, I came out, and all the lights on the cluster came on bright, and the dome light was bright too. But when I tried starting it, it just went back to being dim. Anyone know my problem here? I already changed all my fuses. Cleaned the connections to the battery.
Old May 5, 2014 | 09:23 PM
007Cats's Avatar
More info: My car has never had this problem before. The car is at 174k~ miles.
Old May 6, 2014 | 09:34 AM
TexasHonda's Avatar
Check battery cable terminations and cable, particluarly positive, for corrosion causing high resistance. This problem has been reported by others.
good luck
tsx_boy
Dec 13, 2019 08:33 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
ceb
ILX
Sep 27, 2015 10:56 AM
TLguy42
Sep 26, 2015 11:27 AM
