Acrua TL 2006 Front Damage
8th Gear
This my Acura TL 2006, it was hit only in the front. The stuff that need to be purchase is (Fender/Bumper/Hood/Grill), but does anyone know where I can get it fix? I know a guy and he's charging me 8k-9k (purchasing the parts and installation), but I wanted to know if anybody know someone that will do the job for a low cost?
![](http://i190.photobucket.com/albums/z150/JamesL20/Acrua%20TL%2018JUL11/SDC10777.jpg)
![](http://i190.photobucket.com/albums/z150/JamesL20/Acrua%20TL%2018JUL11/SDC10776.jpg)
![](http://i190.photobucket.com/albums/z150/JamesL20/Acrua%20TL%2018JUL11/SDC10775.jpg)
![](http://i190.photobucket.com/albums/z150/JamesL20/Acrua%20TL%2018JUL11/SDC10772.jpg)
![](http://i190.photobucket.com/albums/z150/JamesL20/Acrua%20TL%2018JUL11/SDC10771.jpg)
You've got frame damage, there's no such thing as a "low cost" repair. Pay your insurance deductible and take a higher premium, get it fixed. Especially considering your frame damage is in the front, there could be ALL KINDS of problems spawning off of that. Also, you're missing a lug nut on your donut, and your tread pattern on your rim indicates its on the wrong side/going the wrong way. Good luck with the repair.
p.s.- not that its relevant, but it bugs me, the past tense of "fix" is fixed, as well as purchased for "purchase", and knew for "know.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
The big tell tale sign that there is going to be a bit of work involved is the gap between the fenders and the door. Acura uses ACE body construction which is designed to crumple and absorb energy to keep the passengers safe. If the impact was hard enough you would have crumpled the front area and pushed the fenders back into the door. (do the doors have trouble opening?)
The front bumper is about 600 painted for a new one, each fender is about 500 dollars (painted) and the hood is about 700 painted. Each headlight is going to be around 1K plus all the misc. bulbs and such. Fixing the frame damage is going to be a bit of labor and require specialize equipment.
Also where is your front strut bar (connects the two shocks together at the top in your engine bay) and also what the hell is that on your throttle body? Ebay air intake?
Also the other member is right, your dount is missing a lug nut/bolt, your spare is also low on air. As well your front tire is installed backwards!
8th Gear
The big tell tale sign that there is going to be a bit of work involved is the gap between the fenders and the door. Acura uses ACE body construction which is designed to crumple and absorb energy to keep the passengers safe. If the impact was hard enough you would have crumpled the front area and pushed the fenders back into the door. (do the doors have trouble opening?) Nah the door seem to open up fine & I was doing 40mph when I hit the front.
Yeah the collision body shop I went to they gave me a quote about 8k-9k worth of repair damage.
Also where is your front strut bar (connects the two shocks together at the top in your engine bay) and also what the hell is that on your throttle body? Ebay air intake? Yeah it's a Ebay air intake for now, just for the time being, Just trying to repair the front, before I purchase a good intake. There's a lot of specs I need to get to put under the hood.
8th Gear
Also the other member is right, your dount is missing a lug nut/bolt, your spare is also low on air. As well your front tire is installed backwards!The lug/nut/bolt is in the trunk, and when my cousin gave me the car he didn't bother put air in the spare tire
"Nah the door seem to open up fine & I was doing 40mph when I hit the front"
What the hell did you hit while going 40mph and got such damage?? a mailbox?
If you hit a car in the back doing 40mph that's more than enough force to set off the bags, bend the frame and even deform the pillars. You can easily total your car with a 40mph impact.Since your frame is bent 9k sounds about right.
And Please, take off that damn filter or photo shop it out of this pictures, that thing is a disgrace to any engine and should be destroyed immediately.
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
just adding to the previous post. This is 40mph impact into a solid object. If it was a car it would be slightly less damage but would most likely total the car..
perfect crumple zone btw..took it like a champ
http://www.youtube.com/watch?v=0ScLSNK_V7g
ON a lighter note, this is a car where the Crumple zone is the ENTIRE CAR and the frame was probably plastic. By the way, that's also 40mph
http://www.youtube.com/watch?v=nUNMO...eature=related
Oakes
Wash & Wax
10-12-2015 11:17 AM
