Acceleration wavvyness
Old 10-10-2017, 10:34 AM
Sandan's Avatar
Hello peeps,
Mime is a 2004 TL 6MT.....
SO I researched and found nothing that resembles my visitation....I am getting acceleration waviness....Like I am driving on the highway and am on the accelerator and holding steady.....but my car behaves as if I am gently pushing and releasing the gas pedal that is the kind of motion feeling I get and the car behaves the same....But if I set up the cruise control nothing...only when my foot if holding steady the accelerator it does that....
Any inshights on this behaviour and any diagnoistics is much appreciated.
Sandan
Old 10-10-2017, 11:20 AM
truonghthe's Avatar
Received 1,694 Likes on 1,308 Posts
check your APP sensor, it might starting to go bad.
WDPanda (10-16-2017)
Old 10-10-2017, 11:39 AM
Received 16,267 Likes on 11,974 Posts
EGR blocked full of carbon deposits?
Old 10-10-2017, 05:18 PM
Jackass's Avatar
To me...the difference in behavior from manual vs cruise leads me to say APP sensor as well.
Old 10-12-2017, 11:43 AM
2007 6SMT Type-S
SurfingScotty's Avatar
Are started noticing a similar issue about 2 weeks ago. I have a 6SMT and noticed this behavior at slow speeds/slow RPM's while maintains speed or accelerating gently. Yesterday while on the freeway my CEL came one and I got a vehicle stability assist 83 message. The car seemed very sluggish. I pulled over, shut off the car and restarted it. All warning lights get me now accept CHL. Car is acting "normal" per the last 2 weeks. Suggestions?
Old 10-12-2017, 11:45 AM
Received 8,756 Likes on 6,753 Posts
check your battery terminals
Old 10-12-2017, 12:28 PM
Latent car nut
horseshoez's Avatar
Received 2,036 Likes on 1,423 Posts
What is a "6SMT"?
Old 10-12-2017, 12:40 PM
6 speed manual transmission
Old 10-12-2017, 03:21 PM
2007 6SMT Type-S
Correct.
I'll do some more searching but is the APP sensor or EGR valve hard to access?
Old 10-13-2017, 09:40 AM
truonghthe's Avatar
Correct.
No, both item can be service/ replace less than 20 mins.
Old 10-16-2017, 06:54 AM
Sandan's Avatar
Peeps,
Update: replaced APP sensor problem solved...
Happy Customer....
Thank you for all the help .. ....now tell me where to locate the EGR valve...
Sandan
Old 10-19-2017, 12:54 PM
2007 6SMT Type-S
Confirmed codes; APP sensor as well. Mine just arrived for $165 + shipping.
Old 10-19-2017, 04:38 PM
truonghthe's Avatar
Originally Posted by Sandan
Peeps,
Happy Customer....
Sandan
its here locate in the red circle
the EGR passage is inside intake manifold (if you need to clean whole system)
SurfingScotty (10-20-2017)
Old 10-20-2017, 07:06 AM
2007 6SMT Type-S
Awesome! Thank you! I'll take care of this tonight.
