AC compressor fuse drain battery
Old Jul 2, 2017 | 02:05 AM
Daniel Koerner's Avatar
Hello,
I have 2008 Acura TL and the AC was blowing coolant threw the car one day after work. The next day my car was dead. So i did the voltage test with a voltmeter and found that fuse that controls the AC compressor was staying on when the ignition was off. so when i pull that fuse the draining stops but i am left with no AC. Don't know what to do.
Old Jul 2, 2017 | 06:28 AM
peter6's Avatar
​​Relay that energizes compressor clutch is probably stuck. Pull that relay out and check if drain stops.
If so, replace it.
There's thread somewhere with photos of fuse box. If you can't find it, or relay, make photo of your fuse box and post it here.
Should be #4
