ABS and VSA light on
Old Aug 3, 2020 | 09:34 AM
BlaccChino's Avatar
6th Gear
I was working on my car the other day I changed the LCA’s and the ball joints. In the process of trying to get my hub off I tried to take the wheel speed sensor out of the hub and broke it. So I ended up getting a new wheels speed sensor and replacing my old one. I rode for 2 days no abs light. I was driving down the interstate the 3 day after the repairs and my abs and vsa lights are on and won’t go off. I had the abs scanned it’s telling me “Right pulsar malfunction” was wondering if anyone else had this problem, if so how’d you fix it.
Old Aug 3, 2020 | 11:00 AM
Ted Kief's Avatar
If you used aftermarket parts this may be your problem
Old Aug 5, 2020 | 06:07 AM
DMZ's Avatar
DMZ
Head a da Family
And / or incorrectly installed may be the problem.
Old Sep 17, 2020 | 03:19 AM
jyang0311's Avatar
6th Gear
I'm having the same issue... There's days the VSA and ABS light comes on and off when I start my car up... One day when I started up, no indicators was lit up but then I noticed it comes on when I press brake while driving... any help well be appreciated....
Old Sep 17, 2020 | 08:51 AM
peter6's Avatar
You need a scan tool to retrieve codes (if any) and check what speed each wheel is reading.
Old Sep 17, 2020 | 09:56 AM
jyang0311's Avatar
6th Gear
I've tried different scan tool. Every one I used gave me an 02 sensor reading.
Old Sep 17, 2020 | 05:49 PM
peter6's Avatar
You need a scan tool that can communicate with VSA/ABS module, not only a "code reader". $10 ebay bluetooth plug won't do it.
Simple scan tools that allow for that probably start ~$100, bi directional scan tool probably starts ~$800.
jsch6584
Nov 12, 2023 06:50 PM
kcast5600
Jan 18, 2020 06:49 PM
smooth CL-in
Jan 4, 2008 11:53 AM
Yui
1G TSX Problems & Fixes
Sep 21, 2003 08:07 PM
Blue-CL-Type-S
Mar 29, 2002 11:24 PM
