Abs and vsa light on!
Old Oct 16, 2009 | 04:21 PM
HigdonTL05's Avatar
Angry Abs and vsa light on!
Today drove to work and everything was goodn, leave for work turn on car and my VSA light is lit as well as my ABS light... any clue i searched and found a similiar thread but no responses
Originally Posted by f5freddyj
Recently got caught in the sierras and let's just say the 2004 TL is not built for eighty inches of snow.
After being stuck for a couple of days, i was winched out of a driveway by a tow truck. But now I've got an abs light and my vsa wont turn back on. (turned it off to try to spin my wheels out of the driveway where i was stuck)
I think a sensor may have frozen (checked fuses)
The car seems to drive fine. Anyone have similar problems after encountering frozen tundra?
HELP I READ THE OWNERS MANUAL AND IT SAYS IF THOSE LIGHTS TURN ON AND WONT GO AWAY DRIVE TO A DEALER TO HAVE CHECKED, I DONT THINK ITS A SEVERE PROBLEM TO DRIVE TO A DEALER ASAP!!! PLEASE HELP!
Old Oct 16, 2009 | 04:26 PM
HigdonTL05's Avatar
It may help to add i just got new tires and went to a 245/45/17, it said something in the manual about changing tires sizes may cause this issue but i know tons of guys on here run that tire and i have never heard of this problem!
Old Oct 16, 2009 | 05:58 PM
SatinSilverAV6's Avatar
2003 Accord Coupe V6
i bet its a bad abs wheel speed sensor! I had the same issue! My ABS light and TCS light was on. You have 4 speed sensors. You now just have to figure out which one it is.
Old Oct 17, 2009 | 02:54 PM
HigdonTL05's Avatar
and how much are those? and are they easy to replace? and is it worth just replacing them all?
Old Oct 17, 2009 | 08:15 PM
NedShneebly's Avatar
practicing nihilist
search "wheel speed sensor". couple threads on checking and cleaning them. they must have a specific static clearance between the sensor and stator unit. I've been f-ing with these on 19's for 2 years.
they're only like $30 a piece at one of the good online vendors: acura carland is a good one. but I bet it's from the tire change.
Old Oct 19, 2009 | 05:57 PM
HigdonTL05's Avatar
did alittle searching but still can not find a decent picture of where this is located on our car anyone have a picture of it or a DIY for this? kind of want to tackle this on my own
Old Oct 20, 2009 | 11:09 AM
practicing nihilist
Wheel Speed Sensor Diagrams
WSS Diagram
Can't view the embedded pictures from my work computer but, I think this has the service manual pages.
It's in the 3G Garage. You can see the lead running from behind the caliper into the wheel well.
Old Oct 20, 2009 | 03:55 PM
TL-S121's Avatar
What code did it give u ?
Old Oct 20, 2009 | 05:30 PM
Zigma's Avatar
Hi, It can be a bad ABS sensor. They are right underneath beside the wheel.
I had my wheel bearings from the front changed about a year ago and the mechanic ended up screwing up the sensor causing the abs vsa light to be on. After fixing the first one, they ended up breaking the second one lol. They then could not figure out how to program VSA feature or something (Can someone go into detail on this? No idea what they ment by that, it was a shop).
Old Oct 20, 2009 | 06:02 PM
HigdonTL05's Avatar
I believe its a bad wheel sensor cause 2 days after i got my new tires it went off... thanks for the diagram NedShneebly that helped alot on figuring out where these are. Tommorrow im going to start taking the wheels off and playing with them a bit. I kind of feel like the tire shop did something to disturb them...
Old Oct 20, 2009 | 08:03 PM
practicing nihilist
keep us posted. I'm praying my recurring VSA and (!) light is related to the speed sensors. I've been waiting on a brake job to crack them open.
the very first time I ever received the above lights was after going to a car wash stall and using the high pressure wand to spray out the wheel wells.
Old Oct 20, 2009 | 08:09 PM
I hate cars's Avatar
Good advice given so far. You did replace all 4 with tires of the same size, right?
Old Oct 22, 2009 | 10:20 PM
HigdonTL05's Avatar
yes i did, going away this weekend didnt have time to screw with anything just going to enjoy my trip to texas and when i get back ill start to tackle this cause those lights are quite annoying!
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Stu2414
Aug 30, 2015 07:30 PM
