ABS/ECU location??
Old Oct 17, 2011 | 09:20 AM
godfather18's Avatar
ABS/ECU location??
Hey guys in trying to replace the abs computer and I looked behind the glove box and I couldnt find it there. Any ideas where it could be??
Old Oct 17, 2011 | 10:16 AM
Here is a picture of it
Attached Thumbnails ABS/ECU location??-391692731_o.jpg
Old Oct 17, 2011 | 12:24 PM
Bump???????
Old Oct 17, 2011 | 04:25 PM
Come on members help me out here??
Old Oct 17, 2011 | 05:54 PM
KN_TL's Avatar
It's near the ecu below the compartments
That picture doesn't match what's in the service manual. There are 3 connectors in a row.
Old Oct 17, 2011 | 06:56 PM
I checked below there and all I saw was the ECU I didnt see that black box down there and what page in the manual can I see this??
Old Oct 17, 2011 | 08:03 PM
KN_TL's Avatar
23-17
Old Oct 17, 2011 | 09:49 PM
23-17 is the SRS airbag module thats not the ABS ECU??
Old Oct 18, 2011 | 08:11 AM
KN_TL's Avatar
Oh geez, I'm sorry.
I just looked under brakes and the only thing I see is behind the gauge cluster.
Look on page 19-3 and 19-11.
Old Oct 18, 2011 | 11:34 AM
nfnsquared's Avatar
Do u mean the ABS modulator unit?
For the ABS, as far as I can tell, the main control units are the ECM/PCM and the ABS modulator unit (on top of passenger fender).
Old Oct 18, 2011 | 06:59 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
+1
There is no ecu per say but the abs brain of it all is the ABS Modulator which is big bucks if it's bad. Just like Nfnsquared said open the hood, remove the passenger underhood cover and it's right there infront of you. There's a huge swing type connecter and there are a few brake lines going to this modulator.
Old Oct 18, 2011 | 07:29 PM
vill0169's Avatar
AZ Track Whore
can you find a part number on that? Whats the point of all this anyways? Who told you that was the ABS computer and what problem are you having?
Old Oct 22, 2011 | 06:53 PM
Well I replaced the rear right ABS sensor because it kept saying rear right abs sensor fault/short circuit and then I replaced the abs ring on the hub and it still kept saying rear right abs sensor fault/short circuit. I checked the wire going from the sensor to the abs modulator and the wire is fine so i am trying a process of elimination. Could I have a bad main ECU/ECM or is it the abs modulator??
Old Oct 22, 2011 | 10:01 PM
thisaznboi88's Avatar
ooo
Old Oct 22, 2011 | 10:27 PM
SpiderX1016's Avatar
Do you always throw parts at it and hope for the best?
I wish I had your wallet.
Old Oct 23, 2011 | 07:37 AM
vill0169's Avatar
AZ Track Whore
I still would like to know what the part number is for the part in the pic you posted. I'd like to look it up and see what it actually is.
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
malvothegreat
2G CL Problems & Fixes
Sep 29, 2015 08:00 AM
