AAMCO Transmission
Old Apr 14, 2007 | 05:29 PM
Syer's Avatar
AAMCO Transmission
So I stopped by AAMCO transmissions to get the $99.95 power purge.
This means that I get lifetime fluid changes on the transmission. However, I was turned down! What the tech told me was that my fluid is dark in color and it may indicate some hidden problem with the Trany. Mind you my transmission has absolutely no problems what’s so ever shifts into all gears smooth as butter. As anyone experienced this? I have a 2004 TL 110k miles.
Old Apr 14, 2007 | 05:50 PM
subinf's Avatar
One on the right for me
While there can be some relation between the color of the transmission fluid, it isn't a sure indication that anything is wrong. Given the problems Acura had with the automatic transmissions with the 2nd Gen and early 3rd Gen its likely AAMCO didn't want to mess around with anything and somehow have the blame fall on them.
110k, I think you have the highest mileage 04 on the forum.
Old Apr 14, 2007 | 11:43 PM
csmeance's Avatar
i think it was supposed to be changed at 60k, 90k and 110k. If changing for the first time is 110k, then is will be darkened.
Old Apr 21, 2007 | 10:31 AM
kataklyzm's Avatar
alot of times if tranny fluid hasnt been changed, we've seen at the shop that the tranny can stop working just from changing the fluid. sometimes all the dirt and sludge is whats really holding it together
Old Apr 21, 2007 | 11:04 AM
Syer's Avatar
yeah, that is what everyone has said, they told me just leave it. if it is working fine.
they also said you never know with tranys you can have them last 300k or they can just die at 10k you just never know.
i will just put some cash on the side for that day. or i may just trade in when it dies.
thanks for the replys guys i value your opinions.
Syer
Old Jul 29, 2007 | 01:17 AM
SodaLuvr's Avatar
I don't think I've ever seen a Honda vehicle with red colored transmission fluid...the ATF-Z1 fluid turns brown very quickly and it is perfectly normal. Any Honda/Acura dealership tech will be able to confirm this for you.
If you want your transmission to last, I suggest that you disregard the advice that you've been given and have your ATF changed on a regular basis starting now.
Old Jul 29, 2007 | 02:02 AM
01tl4tl's Avatar
Do the 3qts 3 times method Gen 2 uses to change out as much as possible
The power suction wont work on the TL- a metal plate undere the dipstick prevents hose from getting deep enough
Old Aug 7, 2007 | 09:57 PM
Lore's Avatar
CEO, Team Anthracite
Mine is red, but then again, I just got a new transmission today. :-)
Old Aug 8, 2007 | 10:33 PM
SporkLover's Avatar
B16 Swapped TL
Ummmm if someone seriously thinks its acceptable for a tranny to last 10k, tell them to stop buying them from junkyards.
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
