(>_<) VSA Light, Excessive Vibration, ETC.. FREAKING CAR PROBLEMS!!
Old Oct 4, 2011 | 08:43 PM
sk8board{Pete}'s Avatar
So today I'm driving home on the 408 after working a funeral detail with the sheriffs office and the check engine comes on. Like an hour ago, I was driving the car and the vsa light pops up and took forever and a day to accelerate. I pull over turn the car off, no vsa light but the check engine light remains on.
The transmission has well over 200k miles on it and has be shifting gears extremely rough and make all type of clunk an thump noises (not sure if these are the best choice of words).
For the longest time when I began to accelerate, the car will shake. I've changed both axles, passenger side lower control arm, swapped the spindles to the brembo spindles, etc.. The vibration went away, when i install the brembo, and I thought the problem was fixed, but after the first 5-10mins, it was right back.
I think it is safe to say that the transmission is on its last limb.
Also another problem that I noticed, whenever i make a right hand turn, I hear some weird noise. Sounds like a ground is shorting.
Old Oct 4, 2011 | 08:52 PM
..oh the car is an 04 TL.. Using amsoil 10w30 Oil and is about 60%. Always use 93 octane.
I changed the 3rd and 4th gear switch, oil filter and started using amsoil ATF about 2 months ago..
Old Oct 4, 2011 | 09:00 PM
vill0169's Avatar
AZ Track Whore
On the vibration - had the wheels checked? could have multiple bent wheels.
Old Oct 4, 2011 | 09:02 PM
Possible problems:
- The APP Sensor is bad???
Old Oct 4, 2011 | 09:03 PM
Yes I got rid on the 20s and I'm riding on type s wheels.. wheels are good and balanced
Old Oct 6, 2011 | 12:02 AM
gotkilled's Avatar
NBP is a pain...
Check brake fluid. My CEL, VSA, ABS light was on before because there was a leak in the brake fluid line because i didn't tighten it down enough.
Just recently, I started getting the VSA and ! light and can't seem to pinpoint it.
Old Oct 6, 2011 | 06:00 AM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Vibrations can be caused by your motor mounts. 200k and if those mounts where at least changed once check them again. This may be an internal transmission failure which internals can be worn to the point where the transmission will cause a vibration. APP Sensor can also be at fault, usually they throw a CEL before they completely fail. VSA light on is telling you there is a fault in the ABS, traction control system. You need to have it scanned and let us know what the CEL + VSA is on for.
Old Oct 9, 2011 | 07:24 AM
I drove the car to go get the CEL checked out and I turned off and never came on since.
Old Jan 5, 2012 | 02:28 PM
Acuraman101's Avatar
i have close to the same problems with the shaking and vsa and ! light always on.I rotated my tires and think that i'm gonna go get new tires just in case busted belt or somthing..as for vsa and ! i dunno i need help if anyone has any ideas could u pm me.
Old Jan 5, 2012 | 02:29 PM
oh yea i have a 04 tl at with 200k
Old Jan 22, 2012 | 02:16 PM
Royik1157's Avatar
i have the same problem i really need help!! i recently had my axles replaced because of the shaking from 60+. then the axle seal broke and the tranny fluid spilled all out. i had it towed to the shop that did it and they fixed the seal and drained the rest of my tranny fluid. they filled it with new fluid and i noticed that a shaking from 20-40ish. i know that it couldnt be the axles (because they are brand new) and i know its not the wheels or tires because i never had as shaking at that speed with the old axles.
and i was just driving home today and i got a vsa light and traction light on too. it takes forever to accelerate and at times i can feel that my tires slipping like coming off a light at medium throttle. im wondering if its because of the new tranny fluid?? someone please help. btw im at 66k miles on an auto tranny. tranny fluid change was only done once and was about 300 miles ago.
Old Sep 18, 2012 | 10:26 AM
The same two problems exist after the brembo conversion, new axles, a new tranny.. I just gave up and stop caring about this car.. driving it until the wheels fall off
Old Sep 18, 2012 | 10:58 AM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Did you ever look into the app sensor? How long does it take to accelerate?
Old Sep 18, 2012 | 01:41 PM
roof2006's Avatar
Originally Posted by sk8board{Pete}
Possible problems:
This was the answer to the VSA light/no acceleration problem for me. The computer code said "bad throttle body." After we (my mechanic) replaced it 3 times, we still got the problem - testing and replacing the APP sensor solved it.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
kuzdu
Sep 10, 2015 08:42 PM
Stu2414
Aug 30, 2015 07:30 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
