86K Miles CPO, 2005 TL, Vibration when idle
Old Dec 5, 2010 | 06:57 PM
badkenny's Avatar
8th Gear
Hi everyone, about a month ago I noticed that my car start to vibrate a bit extra hard when idle. Few days ago took it to dealer and was told that probably it need a valve adjustment. Was told that it is a part of 105K service and they could do it for me for only $1100. I feel like they are trying to sell me 100k service, any suggestions of what can it be and how much would it cost to repair?
Thanks for your input,
Old Dec 5, 2010 | 07:19 PM
odehboy's Avatar
B A N N E D
Tell them that vavle adjustments are due at 105K, and you car only has 86k. So your car premauterly needs the valves adjusted and it should be wrote up as a warrnaty issue.
Old Dec 5, 2010 | 09:39 PM
badkenny's Avatar
8th Gear
Good point, I asked them about that and the rep said that is not covered by the warranty. Is there a way to find out what exactly is covered under CPO warranty ?
Old Dec 5, 2010 | 11:27 PM
qurious9ss's Avatar
The TL idles rough when cold, so how long have you owned your TL?
BTW, valves for the most part get noisy when they need adjustment so are you hearing valve chatter?
Old Dec 6, 2010 | 01:00 AM
BAGII's Avatar
Yeah, no way the dealer is going to cover valve adjustment at 86K. But, it could likely be a bad motor mount. Out-of-spec valve clearances are more likely to cause a misfire and check engine light.
Old Dec 6, 2010 | 05:09 AM
Turbocoop's Avatar
Id take off the side motor mount and check it out- I almost guarantee its completely F'd inside- mine was @ 95K miles- Im not saying thats the entire problem but it helped mine a lot- I didnt replace it I filled it with shoe-goo
Old Dec 6, 2010 | 09:31 AM
hrod26's Avatar
Search more info on bad motor mounts but ignition could also be the source. I replaced a bad coil pack that showed up as shudder at idle.
Also, please provide more description on vibration. Does it only do it in drive or reverse? Does it sound/feel like a misfire? Is it temperature dependent?
TLDude876
Dec 28, 2016 03:18 PM
Legend2TL
Nov 20, 2015 07:31 PM
handsom-hustla
Nov 13, 2015 05:04 PM
ThermonMermon
Sep 22, 2015 03:36 PM
