6spd manual owners step in
Old Jul 11, 2009 | 09:10 PM
Kostyan's Avatar
I just put 300 miles today on a car and at the end of the day realized that my clutch pedal is giving off some kind of a vibration if slightly depressed. This is not my first car with manual transmission, so I am somewhat concerned. Is there may be something wrong with my TL or I'm just nitpicking?
The symptoms appear only if the clutch pedal is depressed just slightly beyong the regular "free play" region, but before the clutch disengagement point. My TL is an 06 with only 34k mi on it, and no work has been done to it exceot 3rd gear Acura overhaul TSB under wtty
Old Jul 11, 2009 | 09:34 PM
PhilB81's Avatar
I've never noticed with mine but I'll check tomorrow.
How hard are you on the throttle and what speeds?
Old Jul 11, 2009 | 09:53 PM
csmeance's Avatar
Check the fluid for the clutch, also check to see if the master cylinder is leaking...
1fsthatch's Avatar
check your clutch fluid, or bring it to an acura deal for peace of mind i went to go check and mine does not do it i have a 07 type s but the clutches are the same (i think)
Old Jul 11, 2009 | 10:33 PM
SouthernBoy's Avatar
Registered Member
At that point, you're beginning to engage the release bearing. Pay close attention to this and consider having it checked if it continues.
Old Jul 12, 2009 | 12:58 PM
94eg!'s Avatar
#1 Super Guy!
Yes, if the release bearing is going bad, it could cause vibration. Might be worth it to bring it in, even if they don't find anything to be wrong at this time. This is just in case it gets worse, you at least have it on record in an early stage. At least that's what I was originally told about my 3rd gear problem, which was then fixed at a later date because it did get worse...
Old Jul 12, 2009 | 02:09 PM
BG74's Avatar
The clutch pedal isn't directly connected to the clutch itself, so you wouldn't be able to feel any feedback from it.
It's connected to a master cylinder, then hydraulically operated through a slave cylinder. Maybe check to see if the master cylinder or the linkage is loose?
Old Jul 13, 2009 | 07:27 PM
Kostyan's Avatar
I found this is happening at any speed, even when I am sitting at the red light, in any gear. Thanks for confirming that this is not expected for a TL. I will be checking the clutch fluid level tomorr and taking her to a dealer for the next oil change.
Old Jul 13, 2009 | 07:39 PM
freeflowing's Avatar
i'll have to check myself for this. i just had my 3rd gear swaped under warranty
Old Jul 13, 2009 | 09:15 PM
Mattgtp's Avatar
06 6mt A-Spec Navi
Mine is smooth as can be but I once had a Z34 with a 5spd and it had the same problem and they never could figure it out. They replaced everything from the clutch to the master and it always came back then blew apart the release bearing and fryed the clutch twice so I just got rid of the car lol... Have the dealer look at it just to be safe
Old Jul 14, 2009 | 10:51 AM
94eg!'s Avatar
#1 Super Guy!
Even a hydraulic connection is a direct connection. It is capable of sending feedback.
Old Jul 14, 2009 | 12:31 PM
BG74's Avatar
Perhaps some kind of feedback in terms of engagement point or the like, but a high-frequency vibration from the clutch assembly itself and then through the pedal like the OP described isn't possible through a hydraulic connection. Vibration is very hard to transmit through a viscous fluid, especially one that isn't under that much pressure.
You would feel a vibration from the clutch assembly through the floorboard before through the actual pedal.
Old Jul 14, 2009 | 12:54 PM
Integral212's Avatar
On my S2K (also a hydraulic clutch), many owners end up removing the slave cylinder so they can grease the pivot ball and release fork. After a while, it begins to bind. The chattering is transmitted through the hydraulic fluid and is easily felt on the pedal. However, the magnitude is probably a lot larger than just vibration (and it only occurs when the pedal is actual moving since the pivot is what binds).
tonio
Feb 5, 2019 05:43 PM
mugen_kid
Nov 13, 2015 10:38 PM
Silvermoon_Knight
Oct 22, 2015 06:25 PM
asahrts
Sep 4, 2015 05:55 PM
NSolace
Sep 3, 2015 08:14 PM
