6 SP/MT question
Old Nov 25, 2012 | 06:23 PM
Dogfish78's Avatar
6 SP/MT question
New forum member and new Acura owner! Giggidy! I've got a 2006 TL, 6 sp/ MT, Navi., 108000 mi.
I'm a "know enough to be dangerous" mechanic so any help will be greatly appreciated. The question I have is there seems to be a little play in the shifter and I would like to see if there's any way to "tighten" it up a bit. Also, the shifter "clicks" when you shift into and out of a gear. It's nothing major, just noticable. Any insight?
Thanks in advance!
Old Nov 25, 2012 | 06:42 PM
d1sturb3d119's Avatar
Thumbs up
Congratulations first of all... I have a 2004 Tl with a 6 spd and navi too... Great to be the dangerous type of mechanic... You can't really disappoint yourself at this stage if you mess something up... Gets worse when you know a lot and see where you messed up!
Some play in the shifter is natural. If you want to tighten it up you could just replace the shifter bushing. That lies under the hood and you can find more about it in this thread.
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/must-6mt-tl-corsport-aluminum-shifter-cable-bushings-738896/
You don't have to buy just that brand but it gives you an idea of what causes the mushiness... Also prolonged use could lead to that...
The clicking is the best sound in the world and is just crispness... You should be worried if it doesn't click lol...
You planning on doing anything with the car??
Old Nov 25, 2012 | 07:14 PM
sauceja's Avatar
Desert Life Sucks!!
1. Change MT fluid to GM syncromesh "friction modified"
2. Perform slave cylinder check valve delete mod
Optional
Torque dampener upgrade
short shifter
Old Nov 25, 2012 | 08:37 PM
jungy4's Avatar
When you say the shifter clicks, are you saying that the shifter makes a noise like a joystick?
I have the same problem. I thought the only way to fix it is to take the console apart and get a new shifter assembly.
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
