#5 spark plug failed causing damage to the cylinder head
Old May 12, 2016 | 10:25 AM
  #41
Scottwax's Avatar
Mr. Detail
FWIW:
I put my second set of plugs in at 106K using A/S and 13 ft-lbs. I didn't touch them for 108K miles/5 years. I just replaced them at ~214K. None were loose at all...
Basically did the same thing although mine were first replaced at 120k, but same mileage for second set. They weren't loose but kind of surprised how little effort it took to break them loose.
Old Oct 31, 2016 | 10:09 PM
  #42
TL-Syndicate23's Avatar
I just suffered the dreaded #5 plug issue and want to give the Time-Sert a shot. Anyone know what size kit I need to get? Any guidance would be appreciated!
Old Nov 3, 2016 | 07:07 AM
  #43
NetGnome's Avatar
Tips for time-sert
1. Ebay sells a Chinese endoscope web cam with leds that will fit down the spark plug hole. Great for finding chips that fall in and seeing the new spark plug seat is cut well.
2. Grease the tap
3. A small tube connected to a vacuum that you can put down the spark plug hole to vacuum up chips and a chop stick with grease on the tip to reach chips in the corners
4. Measure the distance from the spark plug hole to the top of the spark plug tube and mark that distance on the time sert tap so you don't tap too far down.
5. You can disconnect the fuel pump fuse so the engine won't start, then crank the engine with no spark plug in the repaired cylinder so chips can be blown out.
Old Nov 3, 2016 | 10:47 AM
  #44
I was able to rethread the hole and sucked out what I assume all of the shavings from doing the job. Wondering if an oil change is necessary? Any thoughts?
She's running as good as before the incident. Just scared of WOT driving and down shifting at the moment.
Old Nov 3, 2016 | 10:55 AM
  #45
It's a very cheap insurance, why not
Old Nov 3, 2016 | 11:05 AM
  #46
I have to agree with ya! Gettin it done this weekend.
