4,000 Miles -help
Old Aug 17, 2008 | 01:27 PM
TL|GTX's Avatar
A Black TL
4,000 Miles -help
Okay so, i have about 4,000 miles on my 08 Base TL. Im about to have my oil changed the mid is about 15% oil. So while im getting my oil changed next week or 2, what else should i tell my dealer to change or check? Thanks for the help.
Old Aug 17, 2008 | 02:29 PM
01tl4tl's Avatar
You are too early for the first change.
The special non-detergent break-in oil, allows metal to metal wear the engine needs to establish the parts mating. Change too soon and you short the engine a vital step in its life
Wait till at least 5000 miles- maybe 6000- that should put you at 0-10 percent on the mid- thats fine. Normally it will zero at 7500 miles- the recommeneded change time
At that point you can run the basic dinosaur oil or run the TL on synthetic now
You can switch back and forth with no issues too
If you have any rattles or things the car does you dont understand after reading the owner manual, or you notice a speaker blown - any little thing from assembly- THIS is the time to get it noted and taken care of while in the first 12 month 12k miles
When you go to the dealer- they know what your car needs at the first service-
they make sure nothings leaking and address any complaints- change oil and filter and send it down the road
Old Aug 17, 2008 | 07:37 PM
TL|GTX's Avatar
A Black TL
Well im returning the car in 3 years and even if i buy it out i might keep it for 5 or 6 years top. So im not worried about shorting the engine out as u say? And i heard it was better to change ur oil sooner any way so doesn't matter.
Old Aug 17, 2008 | 08:04 PM
KN_TL's Avatar
01TL4TL is right and your dealer should back up what he is saying.
But if you don't care then why worry about getting anything else done? Your dealer will tell you, they always know best.....
BTW, I only use the dealer for state inspections. That's how convinced that they know the best.
mada51589
Jan 9, 2025 04:40 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
Legend2TL
Nov 20, 2015 07:31 PM
mugen_kid
Nov 13, 2015 10:38 PM
01CLOwner
Oct 9, 2015 01:07 PM
