3rd gear low RPM vibration
Old Jan 17, 2010 | 10:27 PM
cybertron's Avatar
I have a 05 TL with Auto. I've noticed that while in 3rd gear and at low RPMs holding at a steady speed, the car vibrates. But if I step on the gas its gone. Any Ideas? I just got the car used.
Old Jan 17, 2010 | 10:33 PM
218TL's Avatar
mine does the same..dunno what it is. happens at about 25 mph..
Old Jan 17, 2010 | 10:39 PM
cybertron's Avatar
so it's not just me then, I thought I had a tranny problem. I bought the car used and didn't notice it at first but lately I've been driving it and when it reaches about 3rd or 4th gear and 2500-3000 RPM the car is vibrating, its gone if I lift off the gas or step on the gas pedal. But if I am coasting it'll vibrate.
Old Jan 17, 2010 | 10:53 PM
218TL's Avatar
next time you drive see if you notice it at 25mph
Old Jan 26, 2010 | 03:31 AM
5ONE3's Avatar
Just got my 07 TL this past weekend and I've been noticing that in third gear, between 25-30mph, the car/engine starts to vibrate as well. Any ideas?
Old Jan 26, 2010 | 10:50 PM
ha9000's Avatar
4th Gear
I can't believe I couldn't find this thread before I posted this: https://acurazine.com/forums/3g-tl-problems-fixes-114/new-owner-here-have-question-about-noise-vibration-when-accelerating-760794/
Anyway, I noticed the same thins at around 2k-3k rpm. I know I said 3k-4k in the other thread, but upon further inspection, it's just as the OP posted. I took my 07 into the shop today. A tech and I went for a test drive, he noticed it as well. So a day later he calls me and tells me that there is no fix and that it's considered a characteristic of this specific generation. Here is what's written on the repair invoice word for word:
Tech inspected and found nothing loose or any problem. Tech called Techline and they said it is a characteristic A-Pipe make a drone noise.
So I guess this is normal to most and abnormal to a few. I have a feeling the few that notice previously drove a very quiet car. I come from a ridgeline, which is uncharacteristically quiet for a Honda.
Old Feb 8, 2010 | 08:03 AM
cybertron's Avatar
That is so BS! the noise is starting to really annoy me, I purchased the Drone Kit listed in one of the service bulletin. I am getting it installed this Friday so I'll see if it will help reduce it but I don't have my hopes really high on this fix.
Old Feb 9, 2010 | 01:34 AM
diskinnect's Avatar
socal WDP
same shit happened on my 07-08 switching between 2nd gear and 3rd gear between 2k-3k rpm. car starts vibrating but after that it stops when its done shifting gears
Old Feb 9, 2010 | 11:56 PM
Fresh23's Avatar
There is a couple threads about this, did you try changing your tranny fluid and replacing the 3rd and 4th gear switches? that might help, let me look for the thread.
There you go, read that entire thread. https://acurazine.com/forums/3g-tl-2004-2008-93/very-interesting-conversation-my-transmission-builder-tl-721508/
Old Feb 10, 2010 | 06:47 AM
johnny3's Avatar
Cybertron, let us know if the kit was a fix, thanks.
Old Feb 10, 2010 | 08:31 AM
rolan04tl's Avatar
I started getting the 3rd to 4th gear shudder at around 58k miles. I then did some research and decided to change the 3rd and 4th gear switches and did a 3x3 drain and refill of the Transmission Fluid (ATF). Did the switches first and car was still shuddering so I then did the 3x3 ATF change and it fixed the shuddering. Its been about 2 k miles and im still good, however, I have read some reports of shuddering coming back after 3k miles, which I hope does not happen. =)
If you have more than 50k miles on your car and a 3x3 or switch replacement has never been done, I recommend you do both. Both are easy DIY and will cost you about $100 and $80 respectively.
There is tons of good info about this in existing threads, including the one Fresh23 links to this thread, and I recommend you search the forums and read about it
Peace,
Rolan
Old Feb 11, 2010 | 10:05 PM
cybertron's Avatar
I just did a transmission flush at the dealer, not the 3x3 because they wanted $300. Mine isn't shudering, its when I reach higher gears like 4th-5th and at 1500-2000 rpm the car makes a loud vibration/drone noise like a loud HUMMMMMMMMMMM very! annoying!
I am getting the Drone Kit installed tomorrow so I'll post back. Hopefully this fixes or helps reduce it. I don't want to replace the 3rd and 4th switch because I don't notice anything wrong with the tranny as of yet. But that will be something I will look into for my next maintenance
Old Feb 14, 2010 | 01:54 AM
cybertron's Avatar
Ok, so I had the Kit installed yesturday and tested the car today, it seems like it helped, the vibration/drone is still there but only at a very specific speed and RPM rather before where it was anywhere between 60km/h-80km/h at 4-5th gear.
Its a cheap work around as there is no fix so I would recommend installing it.
ExcelerateRep
Sponsored Sales & Group Buys
Jan 6, 2016 09:59 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
HeloDown
Sep 8, 2015 06:51 PM
