3rd Brake Light Glare Issues
Old Oct 21, 2011 | 09:57 PM
Rheklas1's Avatar
Hey all!
Looking for some advice/input around a problem I have with my TL. I'm assuming that its the liner around my 3rd brake light, but at night when I hit my brakes it creates a big red spot on my rear window. Obviously this is a safety hazard as I can't see out of my back window. Anyone experience this before or know of a fix for it?
Thanks in advance!
Old Oct 22, 2011 | 01:18 AM
AtlM5's Avatar
now that i think about it, this has been subconciously annoying me since ive had the car...its especially bad with my tint
Old Oct 22, 2011 | 10:29 AM
SharksBreath's Avatar
BANNED
use some 3m double sided tape and/or window weather stripping and just get the bottom flap on the brake light cover to adhere to the window.
Old Oct 22, 2011 | 10:50 AM
Rheklas1's Avatar
I... I can't believe I never thought to do that... SharksBreath, you just made my day!
Old Nov 22, 2011 | 08:34 AM
Blooze's Avatar
I have my '08 TL in the shop for some odds and ends and mentioned the "bleeding" of light. Turns out that the tech feels that it is "in spec". I am going to give the benefit of the doubt and understand that there is nothing that will come of them replacing/fitting the light cover. Using the stripping is a good idea! Thanks!
Old Nov 22, 2011 | 08:45 AM
BANNED
my work here is done.
Old Nov 22, 2011 | 11:46 AM
9632tl's Avatar
Radical Member
Mine didn't do it (or I didn't notice it) until my windows got tinted.
Old Nov 22, 2011 | 12:11 PM
ez12a's Avatar
the overexplainer
mine does it..still have to fix it one day. Pretty annoying. I believe there's even a TSB for this somewhere.
Old Nov 22, 2011 | 01:39 PM
jokerman826's Avatar
Jokerman
I removed the cover and snapped it in at a very slight angle that keeps the black part tight against the window. I pushed in the clips closer to the window in first and saw that it fixed the issue and did not push in on the other end. If i push in the other end, the angle will go away causing the glare on the window again..
Old Dec 3, 2011 | 04:21 PM
ybtran's Avatar
3rd Gear
going to give your tip a try!
Old Dec 3, 2011 | 08:08 PM
jungy4's Avatar
I actually noticed this too, after I got tinted. It doesn't bother me that much because my glare is close to the deck.
Old Dec 4, 2011 | 08:51 AM
Jokerman
I am trying to find pics to help out, if i cant, once i get my car back from the shop i will take pics.
Old Dec 5, 2013 | 01:13 AM
kenstergo's Avatar
Guys, just to let you know the EASIEST fix to know that the proper way to install the light cover is to press it back and stop after you hear the first click, DO NOT proceed further until you hear the second click.
I dont know why Acura designed it this way, maybe for better removal, but most of us who didn't know better have tendancy to press it all the way in to make sure it is securely installed, don't do that. Once is enough, if you press it back all the way in(hearing two clicks), the rubber skirt will end up lower and create a crack to let the brake light leak out. Hope that helps.
Old Feb 2, 2014 | 12:44 AM
STC's Avatar
STC
I bought a 3G TL today and noticed the glare tonight. Very annoying.
mada51589
Jan 9, 2025 04:40 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
nishant11
Sep 2, 2015 10:34 AM
Nicho863
Sep 2, 2015 08:12 AM
