3rd Brake Light Cover- Adhesive Wearing Out
After a thorough search, I couldn't find anything on this subject here on AZ, but if my memory serves me right, I remember reading a TSB about this a while ago.
Anyway....
Using this diagram as a reference:
Part #25, the third (high) stop light cover assembly, is attached onto the rear windshield using some kind of adhesive. Now this adhesive has worn out, and I need to find some way to reattach it securely onto the windshield so there is no gap.
The main reason for this is because at night, when the third tail light turns on, it shines onto the windshield and the speaker area, making it hard to see behind me while driving. Obviously a safety hazard.
Has anyone else experienced this problem, and what was your fix? Ideally, a kind of adhesive to put in its place.
I would go for the TSB normally, but the Acura dealership is in Salt Lake (three hours round-trip, not counting how much time I'm at the dealership) and because I never go there, they give me the run-around for doing TSB work. "Goodwill" work hasn't worked in the past either, since they know I live far away, didn't buy my car from them, and will move away this year after I graduate college.
Many thanks in advance!
Anyway....
it's not an adhesive, just a rubber lip that should seal against the glass.
I just fixed mine last week by ripping off the cover, then getting a thin strip of adhesive insulation foam (available at Home Depot or Lowes, etc.) along the glass (not the rubber part of the gasket). The rubber now sits on the foam and seals the light from leaking.
I have tints on my rear that are cut around the brake light so I used that as a guide.
The TSB #06-024 referred to the fabric cover coming loose. That happened to mine and the dealer just replaced the cover.
Excellent info, and thanks for the quick response. That definitely helps clear it up!
I doubt I'll go all the way to SLC and back for one repair like this, especially since they have no reason to give it to me as a goodwill consideration (for the reason I already posted).
If I was to do this on my own, not using the insulation foam that was mentioned, would I need to purchase a new cover and clips, or just the clips?
I can't really say, but the TSB has a pretty good diagram on how the cover is attached that should give you some insight on how to proceed.
That light leak really bothered me wher I had it, good luck with the fix.
I've taken mine off to clean the glass before and inside of the light cover.
I wouldn't use double sided tape, it's going to make it a mess to try to get it off again later and clean up the double sided tape from the glass.
I'd try just cleaning it and putting it back on unless something is peeling up.
I used the foam with adhesive method mentioned above to fix mine. I found this two-sided adhesive foam I got from Home Depot a while back and it did the trick. I attached it to the tint so it can't be seen from the outside.
3rd brake light cover by kfanciu, on Flickr
Very poor design on this piece -- it's almost like it was an afterthought.
3rd brake light cover by kfanciu, on FlickrVery poor design on this piece -- it's almost like it was an afterthought.
mada51589
Jan 9, 2025 04:40 PM
asahrts
Sep 4, 2015 05:55 PM
