3G TL reverse tilt mirror and reverse light not on
Old May 20, 2019 | 10:03 PM
dea7hr0w's Avatar
Hi all,
I have replaced the fuse #4, #20, #21 to 10amp from 7.5 amp. I am still unable to have the mirror tilt down while reversing (yes the knob is selected L/R). The mirror can still move if i were to set the knob to (L/R)
on the same token my reverse light does not work either. Even if i had replaced the light bulb still does not solve the side mirror for not tilting down.
Can someone help since I rely on my reverse light and would be nice to have my mirror tilt again.
Old May 20, 2019 | 10:05 PM
dea7hr0w's Avatar
I have also researched on this form but never truly found an answer
Old May 20, 2019 | 10:38 PM
csmeance's Avatar
It sounds like the car is having an issue detecting you are in reverse! Does R light up on the dashboard when you put it in Reverse?
Old May 20, 2019 | 11:56 PM
dea7hr0w's Avatar
Sorry to mention. I have a six speed. No "r" light on dashboard.
Old May 21, 2019 | 09:56 AM
peter6's Avatar
I have zero experience with manual TL so don't trust me too much, but there must be a switch that detects the transmission to be in reverse.
Service manual points to the switch that is in the body of the transmission under the battery.
Old May 24, 2019 | 06:39 PM
dea7hr0w's Avatar
Thank you I will give it a shot and provide a follow up if this works.
Old Jun 14, 2019 | 07:28 AM
Jljr724's Avatar
6th Gear
I have an 07 tl (manual) n have the same problem backup cam doesn’t come on, backup lights don’t come on nor do the mirrors tilt. Did you figure it out?
Old Jun 14, 2019 | 03:22 PM
subinf's Avatar
One on the right for me
Does either mirror ever adjust itself on its own? Or will it always remain in the position/angle that you've selected?
Old Jun 14, 2019 | 03:52 PM
Jljr724's Avatar
6th Gear
My TL never adjusts the mirrors stay set in the selected location. On a side note my whole navigation display just recently stopped working not sure if it could be related
Its my moms car
Apr 15, 2014 01:47 PM
Luchin
2G TSX Problems & Fixes
Jul 28, 2011 01:19 PM
randomwalk101
Mar 13, 2002 10:39 PM
Mstyle
Mar 21, 2001 09:37 PM
doopstr
Mar 21, 2001 08:56 AM
