3G TL reverse tilt mirror and reverse light not on
Hi all,
I have replaced the fuse #4, #20, #21 to 10amp from 7.5 amp. I am still unable to have the mirror tilt down while reversing (yes the knob is selected L/R). The mirror can still move if i were to set the knob to (L/R)
on the same token my reverse light does not work either. Even if i had replaced the light bulb still does not solve the side mirror for not tilting down.
Can someone help since I rely on my reverse light and would be nice to have my mirror tilt again.
It sounds like the car is having an issue detecting you are in reverse! Does R light up on the dashboard when you put it in Reverse?
I have zero experience with manual TL so don't trust me too much, but there must be a switch that detects the transmission to be in reverse.
Service manual points to the switch that is in the body of the transmission under the battery.
Slpr04UA6 (05-21-2019)
My TL never adjusts the mirrors stay set in the selected location. On a side note my whole navigation display just recently stopped working not sure if it could be related
Luchin
2G TSX Problems & Fixes
07-28-2011 01:19 PM
Mstyle
03-21-2001 09:37 PM
