.30 Oversized Engine Rebuild kit
Old Nov 11, 2014 | 08:58 AM
turbofrancis619's Avatar
8th Gear
Hey AZ so I recently found out that I need to rebuild my motor. I was wondering if any of you know any websites that I could buy an engine rebuild kit that goes .30 over-sized on the pistons, piston rings and head gaskets. Thanks
Old Nov 11, 2014 | 04:14 PM
Turbonut's Avatar
Don't know any off self pistons, but custom always available:
Sample Custom Piston Drawings - JE Pistons
Old Nov 11, 2014 | 07:57 PM
mzilvar's Avatar
OEM makes a 0.25mm oversized kit, duno about 0.30
Old Nov 12, 2014 | 02:51 PM
TacoBello's Avatar
Why 0.30 over? What happened with your engine in the first place?
Old Nov 14, 2014 | 09:45 PM
8th Gear
My mechanic suggested .30 but he said .25 would do
Old Nov 15, 2014 | 01:33 PM
mzilvar's Avatar
it's expensive, $113.91 per piston set and $88.82 per ring set for the 0.25mm oversize from acuraoemparts.com
probably be a lot less expensive to find a used block that could be swapped in
http://www.acuraoemparts.com/delray/...All&vinsrch=no
oyayjoe
Jan 1, 2019 10:17 PM
ibGTV
Sep 28, 2015 03:40 AM
oyayjoe
Sep 12, 2015 04:40 PM
EE4Life
Sep 11, 2015 10:13 PM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
