2008 TL transmission filter?
Old Jul 12, 2019 | 02:13 PM
tunde olurebi's Avatar
I've done some online researching and where everyone else is transmission filter is I don't see one please help. 2008 Acura TL 3.2 l engine
Old Jul 12, 2019 | 02:19 PM
ttribe's Avatar
MODERATOR NOTE: Thread moved to model specific forum.
Old Jul 12, 2019 | 02:29 PM
05 Acura TL's Avatar
CAD Guy
If I remember correctly only the 04-06 Auto TL's have a filter that is serviceable, as well as an internal one that isn't?, the 07-08 have an internal filter that can't be serviced without dissembling the transmission.
Old Jul 12, 2019 | 06:12 PM
csmeance's Avatar
04-06 only have access to the filter. 07+ do not have access unless you take the transmission case off.
Old Jul 13, 2019 | 09:17 AM
thanks for replying guys! That's what I'm assuming. But I called my local Acura dealership and they told me I have a in-line serviceable filter. When I went to AutoZone they also pulled it up for my year make and model.
Old Jul 13, 2019 | 10:42 AM
sparc's Avatar
sometimes you'll see parts catalogs get confused and 04-06 parts pull up for 07-08 TLs. As others stated, 07-08 transmissions require disassembly for the filter so it's not recommended on just a regular maintenance basis.
Change the transmission fluid if it hasn't been done in a while. That's even more important.
Old Jul 14, 2019 | 11:44 AM
truonghthe's Avatar
its serviceable filter but what they fail to tell you is that your transmission housing must come off the engine block in order to get to that filter. My mechanic work at the dealer told me as long as you do 1x3 (like me 15k miles per drain and fill) the filter should not to be worry about.
Old Mar 21, 2020 | 01:38 PM
Catzilla's Avatar
Wow I should've searched before ordering the $20 filter.
