2008 TL with 63k pissing transmission fluid?
Anyone ever have a transmission leak in their 3g? I've had my car for about 6 years and haven't had many issues with it. When i first bought it i did replace the ATF with redline. Along with a 3x3 change. Leaving work i noticed it was very sensitive to the gas peddle and the RPM's would stay high and not want to shift. Pulled back into work and noticed i had a small puddle of tranny fluid under the car. Anyone else have problems with leaking transmissions on their TL? Crossing my fingers its a simple fix.
I had one of the half shafts pop out and dumped fluid down the highway until I looked in rearview. Acura replace twice with after market until I insisted on OEM half shaft. Also insisted that they document in their system so that if I had a transmission failure that we had a record. That was about 100,000 miles ago, so no long term.
Find the source of the leak and check the axles.
I second this possibility. When I bought my 08 TL last year, I did the 3X3 transmission fluid change and replaced the three transmission position switches. Shortly thereafter I noticed fluid leaking from under the front of the car, which turned out to be transmission fluid. Luckily the leak wasn't major, and I was able to get it to a transmission shop. They diagnosed the leak as coming from one the of transmission cooler lines going into the bottom of the radiator. They were able to re-secure the fitting that was leaking, and so far so good. I did buy a replacement Denso radiator from RockAuto to have on hand just in case the leak reappears. From what research I did last year when the leak showed up, this seems to be a common issue with the TL's.
