AC not blowing through dash vents
Old Aug 27, 2017 | 10:35 AM
Tyler Thompson's Avatar
Hey Acura buddies
so my 04 Acura TL AC or heat won't work. I can feel the fan kick in but nothing comes through the vents. I have a new blower motor so that is something to eliminate off the list. Any ideas on what it could be?
Old Aug 27, 2017 | 12:34 PM
GreenSpades's Avatar
Did you closely examine all of the fuses? Try swapping them if you have any that are suspicious.
Old Aug 29, 2017 | 09:20 AM
314_04TL's Avatar
Question when the blower motor was replaced. did you replace the cabin filter as well? I was going through a similar situation and I found out that the cabin filter was super clogged
Old Aug 29, 2017 | 10:46 AM
I replaced the blower motor last week. Did not check the cabin filter. It will work at times then it will stop. How do I access the cabin filter?
Old Aug 29, 2017 | 11:01 AM
https://acurazine.com/forums/third-g...ewbies-553554/
Look in there for DIY's on the Cabin air filter
Old Aug 29, 2017 | 11:26 AM
314_04TL's Avatar
It's super easy takes maybe 15 20 mins
Old Aug 29, 2017 | 04:38 PM
nfnsquared's Avatar
Probably the resistor for the blower motor. Do a search, there are a few threads about it. Easy and cheap fix, ~$40 IIRC.
