2008 acura tl type s random misfire
i got a random misfire all the po 300 and so on comes up. i adjusted valves, checked for intake leaks, and cleaned out the egr valve and it still giving me misfires i dont know what else to check for has anyone had this problem before
I would trouble shoot the spark plugs and coilpacks first. if those come back clear, I then would get a compression test and leak down test to confirm if lost compression due to the money shift.
or could be a catalytic converter problem
who knows!?
you'll need to trouble shoot for these things
who knows!?
it's a 9 year old car. things go bad. so, if it is the cat. change out the cat
a cat going bad indicates other problems...mainly fuel....
what kind of fuel are you using?
and it's possible the previous owner used the wrong grade of gas or performed the money shift.
