2007 TLS have LED problem-hyper flash help
I have a 2007 TLS and I have led switchback in the front turn signal and led bulbs in the rear signal and I install 2 resistors in the rear 50watt 6omhs and I still get hyper flash what should I do guys
Have you tried modding the indicating unit itself?
https://acurazine.com/forums/3g-tl-2004-2008-93/g-109-diy-eliminate-led-bulb-induced-hyper-flashing-without-load-resistors-815219/
Check that link out...
BANNED
NEED MORE INFO.
BANNED
well lets not get ahead of ourselves here. if they were wired up correctly then you would not have hyperflashing.
check out this thread, it's easy to follow.
https://acurazine.com/forums/3g-tl-2004-2008-93/diy-front-turn-signal-led-load-resistor-install-872889/
make sure that when using the t-taps, that you press them FULLY onto the wire you are splicing. use pliers and squeeze each one pretty good to ensure a good connection.
i just did this mod on a buddy's 07 TL-S last weekend and everything went smooth. btw the same concept for the front signals applies to the rear signals as well, except the rears are a little easier because there is only ONE positive and ONE negative wire coming off of each bulb connection.
BANNED
^you need 4 resistors total. 2 for the front turn signals and 2 for the rear. you need a resistor for each LED bulb you're using.
Oh ok but can I put all 4 in the trunk instead of tapping in the front wires cuz I really don't want to tap in the front bro because I herd a lot of people out all 4 resistors in the trunk
Yeah just put them at the trunk.
MetalGearTypeS
08-29-2016 08:28 PM
