2007 TL glove box rattling
Old Jan 31, 2007 | 07:16 PM
mikiTL's Avatar
I have a rattle that seems to be eminating from the (passenger side) GLOVE box. It does not rattle when its open. It does when its closed, on mildy bumpy road surfaces. It does not rattle when I hold it closed. Possible solution?
Old Jan 31, 2007 | 08:00 PM
honda nut's Avatar
glove box rattle fix
Make sure the latch inside glove box is tight ! On mine one screw was loose, then I adjusted the latch by pushing up on latch with the end of a hammer handle. It pulled in the door to fit tighter. Hope this helps!
Old Jan 31, 2007 | 08:54 PM
BustedJack's Avatar
The Boss
must be a loose screw... try to tighten all the screws in there
Old Feb 1, 2007 | 07:56 AM
Jim_sir's Avatar
I found that the 2 damper arms were disconected from the glove box. You will have to pull them down and hook them into the pin on both sides of the glove box.
Old Feb 1, 2007 | 10:20 AM
mikiTL's Avatar
thanks for the replies, I check for those 3 symptoms this weekend and see if any are the culprit. By the way, it sounds like its coming from the right side of the glovebox. its soo annoying!
dirleton
Aug 6, 2024 08:19 PM
mlody
Dec 4, 2019 02:11 PM
08KBP_VA
Oct 22, 2019 01:55 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
