2006 TL clutch problems
Old Dec 30, 2014 | 08:48 AM
pgleason99's Avatar
9th Gear
So when I first drive the car my clutch feels fine but as I drive..or if I really bang through the gears the clutch gets very low almost on the floor and there is a ton of play. Sometimes the clutch just sits really low and I pull it up with my foot and it just falls. I can still shift when it does this although it is a pain to get it into first sometimes. I've read that it may be a fluid issue..leaking or a host of other things. Is anyone have this same problem? ? Any help is appreciated
Old Dec 30, 2014 | 08:52 AM
first, you'll have to trouble shoot the issue.
make sure your clutch master cylinder reservoir is full.
next, inspect both clutch master cylinder and clutch slave cylinder.
check for leaks.
if both master and slave cylinder check out; it may be your clutch going out.
I had the same symptoms you have.
after trying all that I could, i finally got the clutch replaced and the problems went away.
Old Dec 30, 2014 | 08:56 AM
pgleason99's Avatar
9th Gear
How much did it cost to replace the clutch?
Old Dec 30, 2014 | 09:00 AM
your experience will not mimic mine.
however; i can show you where to score the clutch kit and if needed the flywheel.
the OEM clutch kit is made by LUK.
and the part number for the OEM clutch kit is 08-047.
google LUK 08-047 and buy the cheapest one you see.
Old Feb 11, 2015 | 09:16 PM
g2redgsr's Avatar
I am having a similar problem with my 2006 TL, my clutch is sticking after i mash the gas so I'm assuming its overheating, any idea on what labor should cost me on this? and is attempting this in my gravel driveway a bad idea? lol thanks!
mugen_kid
Nov 13, 2015 10:38 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Mr.Tea
Sep 14, 2015 09:58 PM
