2006 TL 6 SD. Clutch Fluid change
Old Nov 3, 2012 | 10:31 PM
dljohn's Avatar
7th Gear
I saw an interval for this fluid change sometime ago but I don't know where that was. What is a reasonable cost for this. I know the brake fluid is every 3 years. I don't put a lot of miles on so don't have the maintenance minder to follow. Thanks in advance.
Old Nov 3, 2012 | 10:53 PM
pohljm's Avatar
clutch fluid?
Old Nov 3, 2012 | 11:45 PM
ZOMGVTEK's Avatar
I don't think this is common maintenance or has a recommended interval. I know some other vehicle say somewhere around 3-5 years. It's still not common maintenance. Most people never even touch brake fluid, the clutch fluid matters even less.
I exchanged mine when I got the car, it was a slight golden color, new was nearly clear. It's probably fine to never change it.
Old Nov 4, 2012 | 01:07 AM
ez12a's Avatar
the overexplainer
if it's black, change it.
It's a much smaller system than the brakes, so it shouldnt take too long to flush the old fluid out.
Old Nov 4, 2012 | 11:24 AM
makk's Avatar
Takes $5 and five minutes, why not do it? Just loosen the 8mm bolt on the clutch slave cylinder and top up the reservoir as the fluid level drops. Use clean, fresh brake fluid.
mada51589
Jan 9, 2025 04:40 PM
cobra10363
Jul 23, 2024 04:13 PM
mugen_kid
Nov 13, 2015 10:38 PM
Aleax
Sep 11, 2015 11:31 AM
