2005 TL Transmission?
Old Jan 31, 2014 | 03:23 PM
ty3179's Avatar
Hi. I recently purchased a automatic 2005 Acura TL with 75,000 miles on it. There was a delay when I put the engine in drive and reverse. I had initially thought that it was the engine mounts.
After changing the engine mounts, the problem was not fixed. The shifting into drive was much better but there was still a slight delay. The worst is when I put the car in reverse. There is about a 4 second delay when putting the car in reverse and it feels like the engine is dropping. I took it to a mechanic and they are telling me it is the transmission.
With that being said, I do not feel any issues when actually driving the car, only when putting the car in drive and reverse.
Can someone give me some advice on this?
Is it the transmission based on the symptoms?
Any and all help would be greatly appreciated. Thanks.
Old Jan 31, 2014 | 03:36 PM
main70072's Avatar
It's normal behavior for these transmissions to do that. I'd drain and fill the transmission a few times to get new fluid if it hasn't been done already at that mileage.
Old Jan 31, 2014 | 06:15 PM
Pghpizzaman's Avatar
2004 TL SSM w/NAVI
change your pressure switches also. just search 3x3 drain and fill
Old Feb 1, 2014 | 05:49 AM
YeuEmMaiMai's Avatar
actually it's not "normal" for there to be a delay when engaging the trans. HOWEVER with these units. it seems to be common.
drain and fill with the newest Honda atf. do it every other oil change.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
hashbrown
Sep 29, 2015 12:13 PM
