2005 TL - Shaking/Rattle @ low rpms
Sorry in advance couldn't find any solution under search all found was higher gear higher rpm issue
I'm in second gear at 2500+ rpms an cars running fine
Still in second gear and fall to 2000 rpms and front starts to shake/rattle
I either need to give it gas to up the rpms or break to reduce and fall back to 1st gear
I've read it could be the mount, if so which? (At higher speed/rpms)
All help would be appreciated. Thank you
At idle it runs smooth when it's cold start it has a ticking noise which goes away after warm
If I place it in drive and advance slow thru the gears going to second gear I get the shutter I usually apply more gas to get it out of it.
If I release the gas it also stops. But if I'm in that 2k rpms range and reapply gas shaking starts again
Every other gear change is smooth. Well what I would consider smooth.
I have aftermarket 20" rims and koni shocks everything else is oem this issue was present before the koni shock installation purchased car with rims on it
It's too hard to tell over the internet. It could be the wheels/tires, but that should be speed dependent and not RPM dependent. It could be an engine mount, but that should show up in every gear to some extent. The engine loading is going to change as the gears change, but you should notice it in most gears at some point if you feather the throttle through the range in different gears. A quick visual inspection should give you some indication of the condition of the engine and transmission mounts. Or it could be some internal problem with the transmission.
I would take a peek at the mounts and if they're not cracked bad I would just leave it.
KnuxProd (01-06-2015)
I'll look into the mounts. Just need to find a diagram of the locations.
I was going to perform the motor mount test where e brake is engaged and placed in drive
I've had car since it had 45k miles now it has 122k
Only issue with transmission I've had was leaking but that was fixed by changing out the seals on the cv joints (if I'm not confusing the name) issue was present before that so irrelevant (:
Registered Bunny
If your mounts are original I'm not surprised they might be gone at 122K.
Yeah, mounts are awful in 05 TL's. I freaked out when my Driver's side mount went bad - as it went bad fast. My whole car would shake when I put it in Reverse. It sounded like a motor boat in idle.
I have a feeling that this mount goes bad first in our TL's. Check the mount next to the Power Steering reservoir...it might even have some fluorescent pink marking on it, which I believe is from the factory.
Thanks for all your response
The passenger side has cracks around the bolt area. Front haven't inspected yet.
Acura oem part website is down does nooner have the diagrams of all mounts (engine /transmission) and part numbers
Registered Bunny
Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
Joe Avesyan
09-29-2015 03:57 PM
