2005 TL cranks but will not start
Ok here we go first of all I am a new acura owner and new to the site. Well anyway I bout a tl last week it has 88xxx miles on it. Ran perfect after about three hundred miles I was on the interstate and the check engine light started to blink. I could tell that the engine was misfiring. I got it home and put it in park and it died. Hooked up my code scaner and flaged codes p0300-p0306 which are all miss fire codes. I cleared the codes and tried to start the car it cranked and sounded like it was tryin to fire on one or two cylinders. I bout new plugs and one coil. Started to change out plugs and the #6 cylinder literally had melted in to the head and snapped off then i tried to pull it out. luckly i got it out and was able to change out all the plugs and obviously i put the new pack on the #6 cylinder since the previous one had broke. cranked it over and no ignition the starter engages but dosent sound like there is any ingnition. I have pulled off the intake manifold and and going to clean the fuel injectors i was just woundering if anyone on here had any advice or delt with this before also what fuses should i check and where are they located thanks in advance for all the help
handsom-hustla
11-13-2015 05:04 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
