2005 Acura Tl sputtering
Old Sep 20, 2012 | 02:26 PM
netoracing19's Avatar
2005 Acura Tl 6sp mt sputtering
I have a 2005 Acura Tl 6sp m/t and have sputtering problem especially when the ac is on, also sometimes when I found a stop sign and start going again also I press the gas pedal to pass another car fast I can feel it too, when I use a Lucas deep cleaner helps but after a while the problem come back.
I have replaced the following parts:
Spark plugs (ngk)
Pcv valve
Fuel pressure regulator
Air filters
Sea foamed
Clean throttle body
I will appreciate suggestions
Old Sep 20, 2012 | 03:37 PM
Ron A's Avatar
Administrator
Welcome to the forums.
I deleted your thread in 4G TL because that's the wrong forum for your car, and deleted the first thread you made here since you reposted this thread.
Please continue on here and don't post the same topic more than once.
Old Sep 20, 2012 | 05:05 PM
BukvaMan's Avatar
try a new battery....
Old Sep 30, 2012 | 07:44 PM
nhawks16's Avatar
i have the same currently problem, also read around the forum and no one has a fix for this yet. they say its from the engine being over revved. maybe a compression loss somewhere or bent valve.
Old Sep 30, 2012 | 07:47 PM
05_NBP_TL's Avatar
HE>i
Could be the coil packs
Old Sep 30, 2012 | 08:08 PM
kingkong_dav's Avatar
KingKong_Dav
your fuel pump might be dying. how many miles?
Old Sep 30, 2012 | 09:56 PM
NetoAzul's Avatar
neto as Ernesto?
Old Oct 1, 2012 | 07:58 AM
Renescent's Avatar
fuel pump, fuel filter, coil packs?
Old Oct 1, 2012 | 08:03 AM
nismopowerdqg's Avatar
LowNslowTL
first of all, how many miles are on the motor?
Legend2TL
Nov 20, 2015 07:31 PM
handsom-hustla
Nov 13, 2015 05:04 PM
MyKids&Cars
Oct 13, 2015 11:44 PM
nuldabz
Sep 3, 2015 05:49 PM
