2005 Acura TL Parasitic Battery Drain (quick video fix)
Been a longtime lurker, rarely post, but I made a brief video I thought might save a few folks some time.
If you have a 3rd generation Acura TL (2004-2008) and leaving it parked for more than a few days leads to a dead battery, you should immediately unplug the HandsFreeLink module found in the mirror. I even made a brief video showing you how to do it:
I know this is a common topic, so why share and make another video?
because I was dumb enough to think I'd already fixed the problem a year ago, and I don't want others to make my mistake, so I make it clear how to do it right.
what if my problem is different?
I suggest pulling out the module for parasitic drain issues because statistically speaking, it's the most likely culprit, but as in all car repair, there are a million other things it could be. But it's still wise to go after the most likely problem first... I wish I'd been that thorough a year ago!
what was your mistake?
in 2017, I thought I unplugged the handsfreelink module only to later realize I'd unplugged the garage-door opener module in the same place.
is that all the video has?
no, since I am obsessive about taking notes, I also sampled the current drain at the battery and (though it's not needed for this) thought some other electrical nerds might find this information useful for something else.
is that your car?
no, I grabbed a picture from Wikimedia Commons, my acura is blue and covered in dirt, so i didn't want my dirty car to distract you from the actual troubleshooting, yet I wanted folks who see the image to recognize their own
So if this saves one person from wasting more time, it will be worth it.
oh, and here is a copy of my excel sheet in the video.
is that your car?
Last edited by skaai; 08-30-2018 at 06:18 PM. Reason: answer one more question that I thought others might ask
The following 6 users liked this post by skaai:
6for2 (10-09-2018),
gatrhumpy (01-31-2019),
LoveMyTL-S (02-26-2019),
MarQuis2005 (10-09-2018),
peter6 (10-09-2018),
and 1 others liked this post.
Sweet man, thanks for the input!
Watching your video made me believe I have the exact same problem with my 2007 TL, including the warm spot above the mirror. I haven't tried it yet, but did you consider simply pulling the fuse for the HandsFreeLink. I thought of that, but the user manual doesn't identify a particular fuse for it, though there are a number of fuses that are unidentifiable to me, such as LAF, SRS, IGP, HAC, and others. Any thought on this approach?
Thanks,
Steve Hazlett (TL-k100guy)
Thanks,
Thanks,
Thanks,
no single fuse to HFL
The most direct fuses are the ones under the driver side, the ones in the engine compartment are (by logic and lots of sweat) more general, so removing those kills even more stuff, but if you insist,
- Fuse 15 [under hood] will disable the dash fuses 5,6,7,8,& 9.
- Fuse 6 [under dash] removal reduces current draw to 0.080 (notice this is 2.29 times greater than the 0.035 we want). it also kills the courtesy lights, ignition key light, alarm unit, map lights, roof console, trunk light, and vanity mirror light.
- Fuse 6 + fuse 7 [under dash] removal reduces current draw to 0.040 (which is within range of 0.035 goal). In addition to 6, it additionally kills the climate display, combination switch, gauge module in the instrument cluster, power windows, navigation, blinking LED, power window driver side (maybe all?), and the radio seemed useless too.
Phase 2?
It would be awesome if someone could repair this at the circuit board. I'm sure it would bring great joy to those owners capable with a heat gun and solder iron out there...
***edit***
https://acurazine.com/forums/3g-tl-problems-fixes-114/hfl-fix-youre-welcome-hands-free-link-fix-900427/
***edit***
Gomes35
Can someone explain how to find the fuse or a pic of where to look? Prefer that method over the battery I think. saves all the hassle of reseting my after market deck etc
SBrennan
01-14-2022 05:08 PM
jeffbags
12-26-2018 07:13 AM
MageBeowulf
01-24-2014 11:57 AM
